My car wont start w/ key--HELP - Honda Accord Forum : V6 Performance Accord Forums
Old April 18th, 2006, 10:18 PM   #1
Registered Ab-User
Send a message via AIM to Down4ItChi
Hi Guys. This one is weird. My car fires up normally with the remote starter, but today I only hear a single click w/ no starter when I turn the key. All the indicator bulbs light up normally, beeping normal. Its been happening all day. The battery and alternator are ok b/c remote works fine...I'm confused by this. Any ideas?
I guess I can continue to use the remote , but I can't understand how to fix the problem with the key...
Down4ItChi is offline   Reply With Quote Quick reply to this message
Old April 18th, 2006, 10:24 PM   #2
sonnieeeeboi's Avatar
ignition and key might not have a good contact.
Old April 18th, 2006, 10:32 PM   #3
Registered Ab-User
..would it click though if there werent suffficient contact...?
Old April 18th, 2006, 10:46 PM   #4
Registered Ab-User
ya think it might be a problem with the ignition switch?...just a thought.
Old April 18th, 2006, 11:11 PM   #5
the click sound is from your starter. It could be the ignition switch, but i don't know. Using your remote start shoudl start it up since it basically puts power to the starter to turn the car on.
Old April 19th, 2006, 07:40 AM   #6
Registered Ab-User
I called my mechanic buddy this morn. He said that it could have to do with faulty/loose wiring with my remote starter (which bypasses the ignition switch), or with my blaster ss coil. Otherwise, maybe new ignition switch ($$). Apparently no fuses to check & replace here. boo.
Old April 19th, 2006, 07:49 AM   #7
Registered Ab-User
any other ideas guys?...
Old April 19th, 2006, 11:47 AM   #8
Send a message via ICQ to hightower6969
shouldn't have any problems with the ss coil in the way. I have a cliff remote start and added the ss coil to it after the remote start and everything is fine. You might have to buy a new ignition switch. SS coil has nothing to do with the ignition not turning over, if anything, the coil should turn the ignition better not worse.
hightower6969 is offline   Reply With Quote Quick reply to this message
Old April 19th, 2006, 12:27 PM   #9
i dont think the remote start bypasses the ignition switch does it? I know that the remote has a component to bypass the immobilizer and that the remote start just usually sends poewr to the starter to start? I might be wrong.
Old April 19th, 2006, 02:10 PM   #10
I've had this problem, try turning the key really fast when you try to manually start it.
badboyzproduct is offline   Reply With Quote Quick reply to this message
Old April 19th, 2006, 02:52 PM   #11
Large Member
I think a remote starter does bypass the ignition switch. Its kinda on the same lines as a turbo timer. The engine will continue to run even with the key out of the ignition. As long as the starter itself is getting a signal, it will turn the engine over.
Edit: hehe, didn't realize I would be advertising turbo timers in my post.
Gallo is offline   Reply With Quote Quick reply to this message
Old April 20th, 2006, 10:44 AM   #12
Registered Ab-User
well, apparently it was the ignition switch . I tried the fast fast key turn, cycling/resetting the alarm (I have a Python 881xp--ignition control in the brains..for anti theft), etc. nothing worked. bought ign switch from my buddy, installed it--fired up right away.
thanx very much guys.
Old April 20th, 2006, 11:49 AM   #13
Large Member
You need to stop using that screwdriver to start your car! j/k
Old April 21st, 2006, 10:28 AM   #14
Shifting 5 Gears Baby !!
cowgodv6's Avatar
there is a recall on our cars if the igntion switch fails
I tried to get a new one anyway, but honda tech wasn't enjoying my jokes
I'll check on the Service Bulletin
My Rides :
95 Accord EX-R V6 ( C27M5 ) 5 Speed feels so good !!!
93 Civic Si Coupe ( D16Z8 )
92 Civic LX 4 door Winter Beater - Wife`s winter car (scrapped)
92 Accord EX - Winter Beater
