Need Help, What are common probs with your accord? - Honda Accord Forum : V6 Performance Accord Forums
Old April 20th, 2006, 09:21 PM   #1
-WesMac-
WesMac's Avatar
Talking Need Help, What are common probs with your accord?
Im looking into a 97 v6 for my gf, and its got 125000. It drives real smooth, but the guy said there was a oil leak at one time, he replaced a plate in the fron of the engine, and showed me what he did. I could still smell some oil he said was left on the header from when he replaced the piece. What do you guys think, I have a 99 4cyl, so v6 is not my expertice, and also, what probs can she expect? 98-02 accord v6 trannys are a piece of junk, what about these, what probs in this model?
WesMac is offline   Reply With Quote Quick reply to this message
Old April 20th, 2006, 09:56 PM   #2
bryan <3's bomex
mastadulog's Avatar
the ignition coil
-97 Accord V6-
aim: bpdulog
photos:
myspace:
hincity:
Old April 21st, 2006, 09:28 AM   #3
Shifting 5 Gears Baby !!
cowgodv6's Avatar
yup igintion coil
you're car, seems like it's pulling ok and driving fine. You can get it driving much better by doing this ... change the following
1. Distributor Cap, Rotor
2. Spark Plug Wiring ( get some aftermarket wires 8mm + )
3. Spark Plugs ( Denso Iridiums or NGK Iridiums - I've had both, I love the Densos )
4. Next oil Change do a Full Engine Flush ( if you do them urself )
jack the car up - dump the old nasty oil, leave the filter on - get a cheap oil from wal mart on special - big 5 liter one, put fresh oil in the engine, add the engine flush chemical, leave it run in the car for about 10-15 minutes, then flush the oil out with filter, get a new oil filter and nice mobil1 or valvoline synthetic in there !! it's more less two oil change, but it's well worth it, since you don't know the condition of the driving from the previous owner I suggest it !!
she'll be smooth as hell after these steps
BTW : the engine flush process is the exact same process they use in drag engines
My Rides :
95 Accord EX-R V6 ( C27M5 ) 5 Speed feels so good !!!
93 Civic Si Coupe ( D16Z8 )
92 Civic LX 4 door Winter Beater - Wife`s winter car (scrapped)
92 Accord EX - Winter Beater
Old April 21st, 2006, 06:41 PM   #4
SIR Bound....Slowly
Thundagoose's Avatar
well.. in drag engines they change the oil every run
Check out my car on cardomain!
Here&mpt=[CACHEBUSTER]">
Thundagoose is offline   Reply With Quote Quick reply to this message
Old April 21st, 2006, 07:40 PM   #5
cowgodv6's Avatar
yes every run they flush it out
drag engines are only good for 10,000kms if build NA
maybe 20-25,000kms if mildly turbocharged
I live about 25 mins from napierville dragstrip
My Rides :
Old April 21st, 2006, 08:55 PM   #6
SIR Bound....Slowly
have you run your car there yet?
Old April 22nd, 2006, 03:45 PM   #7
cowgodv6's Avatar
I have when automa**** and it was 16.4 with full interior full subs etc ...
an easy 500 lbs more then what I have now
should be in low 15s high 14s with good tires and reaction times
I'll find out once I mount my falkens and drop her again on the springs
My Rides :
Old April 22nd, 2006, 07:40 PM   #8
Q
accord6's Avatar
5th gen's accord = slow passenger window! LOL, cleaning the tracks helps alittle
Old April 23rd, 2006, 02:40 AM   #9
SIR Bound....Slowly
All my windows go up and down slower than my 12hr days at work
Old April 28th, 2006, 04:39 PM   #10
The 5th Gen V6's are a good solid car. A couple things...
The windows... ahh the windows! They are the slowest things since molasis. I hear if you grease the tracks this will not be so painful when you roll those suckers up/down.
I would go with cowdogv6's advice for the engine stuff. Also the timing belt and water pump needs to be changed probably pretty soon if it has 125,000 on it, possible.
The only other thing worth mentioning is if you would like to have a "direct bolt-on mods" car then the V6 is not the way to go. If you have some adventure and money to do mods then it is a great choice.
Lastly I would say I have had my car for about 5 years now and never had a major problem except the ones I caused Great overall car for performance and quality.
Soelknight is offline   Reply With Quote Quick reply to this message
Old April 28th, 2006, 05:02 PM   #11
sorry to highjack but does anyone think a addition of a oil cooler a good idea on a v6 thats driven daily (3 hours a day, city). Beacuse after my rad failed and i relpaced it with a new one i was looking for coolent leaks and i found oil leaks from the oil pan gasket. Overheating made the oil pressure go up and it came out the gasket, i think?? (college physis is good for something after all)
BossHogg is offline   Reply With Quote Quick reply to this message
Old April 28th, 2006, 07:07 PM   #12
cowgodv6's Avatar
an oil cooler is a great thing to have
we had an oil cooler for the tranny stock
if you want to cool off the engine, well that is a different thing, but very do-able
you can't really effective use a tranny oil cooler for an engine, since the hoses are much much smaller then an engine cooler hose - but that can also be fixed by taking a trip to the local hydrolic shop or hardware store
you can also wire a temp gauge to the sender wire on the tranny cooler and know what temp it's at
some links for ya
http://www.perma-cool.com/Catalog/Cat_page04.html
http://www.perma-cool.com/Catalog/Cat_page07.html
My Rides :
Old April 28th, 2006, 08:55 PM   #13
bryan <3's bomex
mastadulog's Avatar
some links for ya
wait, so youre sayin our cars came with a tranny cooler?
Old April 29th, 2006, 01:10 PM   #14
yep its at the bottom of our rads. also thinking of doing a Oil Catch Can from the pcv or do we alrady have one?
Old April 29th, 2006, 03:23 PM   #15
cowgodv6's Avatar
yes our cars came with tranny coolers
99.9 % of all v6 hondas from 1994 - odessey + have tranny coolers if automatic
some 4 cylinder applications did as well
and according to a resource I spoke to even the NSX had / has one
My Rides :
Old April 29th, 2006, 06:44 PM   #16
bryan <3's bomex
mastadulog's Avatar
nice, i guess that defeats the purpose of buying an aftermarket one. or does it....
-97 Accord V6-
aim: bpdulog
photos:
myspace:
hincity:
Old April 30th, 2006, 09:15 AM   #17
cowgodv6's Avatar
well any cooling addition to any oil or "water" touching part is a good thing
weather it's OE or aftermarket, the fact is that temperatures can drop 20-25% making it easier for more power and less possible for mechanical breakdown
My Rides :
Old May 21st, 2006, 12:12 AM   #18
YeuEmMaiMai's Avatar
all 94+ automatic honda accords have tranny coolers They are oil/water cooler located in the rad tank. I am pretty sure that the older ones have them as well.
Problems with the 5th gen cars
A/C performance (it sucks when it gets REALLY HOT outside)
rust in rear quarters
windows
HVAC knobs
abs modules
V6 engines may have to be resealed (oil pan valve covers crank seals, etc) when they get up there in milage but those motors will run for 300K easily with proper maint.
YeuEmMaiMai is offline   Reply With Quote Quick reply to this message
