Antenna problem - Honda Accord Forum : V6 Performance Accord Forums
Old October 13th, 2006, 02:24 PM   #1
Antenna problem
Hi, I have a probelm with my antenna, it's up but won't go back down. How do I remove the antenna?
Som95ACCORD is offline   Reply With Quote Quick reply to this message
Old October 13th, 2006, 04:57 PM   #2
.308
trapshot68's Avatar
open trunk, remove inner panel on left side of trunk (i think; that's the side the attenae is on correct?) There will be a wire harness. Disconnect and then remove the bolts holding the motor into location.
Then replace electric antenna with s2k antenna.
trapshot68 is offline   Reply With Quote Quick reply to this message
Old October 13th, 2006, 06:54 PM   #3
Where can I get a S2K antenna? and will it fit my car?
Old October 13th, 2006, 07:42 PM   #4
.308
trapshot68's Avatar
s2k from dealership.
as for fitting it to the car, some custom work required. But pretty much it fits. Search on the web s2000 integra antenna swap
