Speedometer gauge - Honda Accord Forum : V6 Performance Accord Forums
Old December 6th, 2006, 06:32 AM   #1
Speedometer gauge
My speedodeter gauge is stuck at 20mph. My quess is because it's cold here in Philadelphia. It was fine 2 days ago. Any idea why it is stuck? thanks
Som95ACCORD is offline   Reply With Quote Quick reply to this message
Old December 7th, 2006, 01:33 AM   #2
Since it's warmer than yesterday, the gauge is working fine. Also I will let the car warm up alittle longer.
Old December 9th, 2006, 07:26 PM   #3
Shifting 5 Gears Baby !!
cowgodv6's Avatar
check da pms
pretty sure is the speedo sensor on the brakes.
the sensor has solenoids and relays around the eletrical run it has, so I would check there, could be a un-clipped or loss of contact
My Rides :
95 Accord EX-R V6 ( C27M5 ) 5 Speed feels so good !!!
93 Civic Si Coupe ( D16Z8 )
92 Civic LX 4 door Winter Beater - Wife`s winter car (scrapped)
92 Accord EX - Winter Beater
Old March 6th, 2007, 11:24 AM   #4
Originally Posted by cowgodv6
check da pms
I have taken the gauge cluster completely apart on my car.. I put leds in it.. any way.. if the gauge is sticking with the key in the OFF position it is the gauge. Take the cluster out and remove the speedometer. There are two little bushings on it.. on under the needle and one in the back under the circuit board. Lube it with some motorcycle cable lube( has a nice needle on it) and make sure the needle moves freely. It should move when you tip the cluster upside down. Just make sure the needle is resting on it's stop when you put it all back together. IF it still sticks you may need to replace the speedometer. If your VSS (vehicle speed sensor) is not working the transmission will shift rough and at odd times and at high revs. and there will be a check engine light on.
97accord-ex-v6 is offline   Reply With Quote Quick reply to this message
