Front signal lamps falling off :( - Honda Accord Forum : V6 Performance Accord Forums
Old January 23rd, 2007, 08:40 PM   #1
vfxraven19's Avatar
Send a message via AIM to vfxraven19 Send a message via MSN to vfxraven19
The screws are fine and not stripped, but the screw holes that the screw grips onto to hold the lamps are stripped. Is there anything I can use to fill up the screw holes to get the screws to stay on? Otherwise, I am using a rolled up chunk of electrical tape tucked to the inner sides to prevent the lamp from budging out.
vfxraven19 is offline   Reply With Quote Quick reply to this message
Old January 23rd, 2007, 08:49 PM   #2
original member!
Nittanys1's Avatar
you can buy some new ones or maybe use some soft glue and put it in there then after it rubberizes screw in the screw. I have two orange turn signal housings for the 5th gen. if interested let me know.
Old January 23rd, 2007, 08:57 PM   #3
There are some metal screw fasteners that look like a U. They should fit over the plastic where you screw in the turn signal lights. What the really do is give the screw something to grab on and will be there forever as long as you do not lose them.
Sorry Im not sure of the name or anything.......
Powder11 is offline   Reply With Quote Quick reply to this message
Old January 23rd, 2007, 08:59 PM   #4
vfxraven19's Avatar
thanks for the suggestions guys! I one or the other... Off to home depot maybe tomorrow
Old January 24th, 2007, 02:50 PM   #5
Q
accord6's Avatar
yup get the tiny metal brackets from the junkyard
Old January 24th, 2007, 07:03 PM   #6
bryan <3's bomex
mastadulog's Avatar
you can get them from the dealer or an autozone. they should be in the body fastener section
