Clunking noise and feeling - Honda Accord Forum : V6 Performance Accord Forums
Old July 27th, 2007, 08:07 PM   #1
Hey guys,
It's been a while, have a 96 accord V6 and I get a clunking noise and feeling when I turn to the right, only sometimes when I turn to the left.
Is this a bad axel? Does anyone have any good tutorials on how to replace one?
I need help...
Thanks,
Don
Don Harrison is offline   Reply With Quote Quick reply to this message
Old July 27th, 2007, 10:43 PM   #2
Its a bad CV boot! You can save the axle, depending on how long you've been running around with a bad CV Boot. I know there is s tutorial i just need to find it. I'll try to find it tomorrow.
-B-
BossHogg is offline   Reply With Quote Quick reply to this message
Old July 27th, 2007, 10:48 PM   #3
-B-
Great,
Any help would be great, It started clunking yesterday. If you can find it what would be great.
Thanks,
Old July 28th, 2007, 08:55 AM   #4
First Check and see if it is in fact your CV boot that is bad here is a link to check your CV boot: http://www.samarins.com/glossary/cv_joint.html
Some people say to change the whole axle insted of just changing the boot which is on the axle. I have had my outter CV boot change twice and not untill I got the whole axle changed did the reaccuring (sp?) CV boot failure stopped.
This is what I found on another site but be foreworned I have never changed my axle or CV boot personally due to the fact I live on a HILL!
http://www.cb7tuner.com/vbb/showthre...=changing+axle
I can scan the manual for you but you can download it from this site and it will tell you everything... here:
http://www.v6performance.net/forums/...ad.php?t=39277
Hope this helps
-B-
Old July 28th, 2007, 12:19 PM   #5
Boss,
Actuall after some lookin, I found the problem to be the front sway bar bushings. They were all but gone. I narrowed down the noise to sharp turns on bumps. We replaced the bushings and all is well.
Thanks for the efford though.
Don
Old July 28th, 2007, 04:56 PM   #6
No prob ..... Im glad it was a easy fix for you.
