lowering opinions - Honda Accord Forum : V6 Performance Accord Forums
Old August 4th, 2004, 11:54 PM   #1
lowering opinions
hey im really new at this and i wantto lower my car. i already have those cheap coilover kits and might put em on. Do they cause any problems in the future? Im thinkin of lowering it 2 inches in the fornt and 1.5 in the back. would that look good? would the performance or handeling be any better? I dont want it to rub and i heard u need camber kits so it wont rub. do u need a camber kit if ur only lowering it 2 inches?
thank you
jonnytran is offline   Reply With Quote Quick reply to this message
Old August 5th, 2004, 02:30 PM   #2
the Lost Sol
KhanhCord's Avatar
the lower u go the the stiffer the ride..i think...camber kits help even out ur tires wear...it'll rub only if u go too low and/or w/ big wheels (i.e. 18")
Old August 5th, 2004, 02:40 PM   #3
bryan <3's bomex
mastadulog's Avatar
you will need a camber kit. if you can, i would try and get hold of a set of some good quality springs i've heard horror stories from the cheap stuff
Old August 8th, 2004, 09:57 PM   #4
what you pay for is what your gonna get, like the above thread says get some better springs and some struts as well. Ive heard horror stories and seen rides that are lowered on the cheap springs....not worth the time and money in the end.
Look around on here in the classifieds or ebay from some ground controls or eibachs. I got my ground controls from laststarburning, im sure other v6p members will give u great deals
aZnAcCoRd02 is offline   Reply With Quote Quick reply to this message
Old August 9th, 2004, 02:56 PM   #5
Large Member
thank you
Give us a little more info on your car. Wheel and tire size? Springs/shocks you're looking for?
I have a '97 with KYB AGX shocks all around and Progress Group springs. My car sits about 2.5" lower than stock. The springs are advertised to lower my car 2.3" but I figure they've sagged a bit in 3 years. I have 18x7" wheels and 215/35/18 tires. I've never rubbed once, front or back, BUT, the ride is much more bouncy and stiff than stock and I do scrape my exhaust (Greddy SP) on speed bumps and driveway entrances.
If your willing to sacrifice ride quality for looks, go as low as you want to. If you've got bucks to spend, go with a full coilover system like a Tein setup so you can experiment with the ride height. You have quite a few options and your wise to ask around before you purchase something.
Oh! Get camber kits!!! I have kits front and back and my tires are almost 5 years old with no signs of unusual wear. I figure I've got about 30,000 miles on my tires and still have quite a bit of tread left. If you go two inches lower without camber kits, plan on buying new tires every 8-12 months depending on how hard you drive. Been there done that.
Gallo is offline   Reply With Quote Quick reply to this message
Old August 28th, 2004, 05:54 PM   #6
alright guys, I'm at the process of dropping my ride and I'm going to use these
http://cgi.ebay.com/ebaymotors/ws/eB...category=33582
What do you guys think? It say it's going to drop 2 on the front and 1.4 at the back. But I think that's for the i4, let see, if it's dropping it 2 then on a v6 it'll be 2 1/2 to 3 right? tell me what you guys think. Thank You
unknownforever is offline   Reply With Quote Quick reply to this message
Old August 28th, 2004, 07:08 PM   #7
bryan <3's bomex
mastadulog's Avatar
yea, its gonna be around 2 1/2 to 3 for the front, but those springs should suit you well
Old September 13th, 2004, 07:13 AM   #8
Shifting 5 Gears Baby !!
cowgodv6's Avatar
hope they won't ride tooo rough
spring compression is very important when it comes to vehicle weight and corner weight
example : a 1350KG 4 cylinder accord can have 6kg/mm front and 4 kg/mm rear ( close to stock compression ) however, a 1450KG V6 accord will make those springs compress more on EVERY ring
I was gonna get a 4 banger set of springs, but then I found out about this factor and I will wait till next summer for a full coilover kit or some really good V6 springs that drop a comfy 2" all around
Old January 4th, 2005, 05:12 PM   #9
cowgodv6's Avatar
well I've changed my mind
I'm gonna get the tein s.tech for 200 $ cdn shipped to my door
should fit well with my gr-2 since it's not that much more of a drop
I'm sure it will be lower then I4 but maybe mm rather then .5" +
Old January 4th, 2005, 05:26 PM   #10
Large Member
Good choice, cowgod. I believe Tein has a good warranty attached to their springs. Something like if they sag more than a certain number of millimeters in the first year, they'll replace them free of charge. They should work well with your KYBs. My AGX's work really well with aftermarket springs. Expect a stiffer ride but you knew that already.
Old January 4th, 2005, 05:30 PM   #11
Yea, get those last time I did say I'm going to get it but then I spend the money on school stuff so I guess I'll have to wait until I save up again Get it and tell me how it handle
Old January 5th, 2005, 05:28 AM   #12
cowgodv6's Avatar
cool guys I will
I'll order them in the spring, no rush to drop my ride in the snow and ice
Old January 12th, 2005, 12:21 AM   #13
hey. if i would get the tein springs, would i need to get shocks for that? i heard that the stock ones with springs are going to mess the shocks up in a year. does anybody with tein springs ahve any problems going up a driveway or anything? i dont know how low it is. i m going to put a ground kit all arround on pretty soon. does anybody have pix? thnx and camber kits are a must have for me because tires arent cheap.
Old January 12th, 2005, 12:42 PM   #14
cowgodv6's Avatar
shocks and coils for better ride comfort
stock shocks suck on 1" drops or more
cause they are not made to handle a drop
GR-2's offer a nice compressed n2o chamber and handle decent ( wife has them on her civic with a 2.5" drop on H&R race coils )
Old January 12th, 2005, 02:37 PM   #15
Large Member
I suggest both shocks and springs. I had Progress springs over my stock shocks for about a month and hated the ride. As Cowgod said, the stock shocks can't handle shorter springs and leave you with a mushy ride. GR2's or AGX's are great with aftermarket springs and they don't cost an arm and a leg. More like just an arm and a foot.
Old January 12th, 2005, 11:55 PM   #16
lol. thnx for the tip.
Old January 13th, 2005, 12:28 PM   #17
cowgodv6's Avatar
forgot to mention I have GR-2 on my accord now, and I installed stock springs and it's a luxury ride
cannot wait for the tein
Old January 14th, 2005, 10:06 AM   #18
cowgodv6's Avatar
getting my tein today @ 4pm
guess what I'm gonna do this weekend ?
Old January 14th, 2005, 10:10 AM   #19
Large Member
Oh do tell, Cowgod!
Old January 17th, 2005, 07:13 AM   #20
cowgodv6's Avatar
got my coils but didn't install them - too cold
got some eyelids to complete the JDM front look
will install the springs when I get some garage time and eyelids when I wash her down
Old January 17th, 2005, 06:58 PM   #21
bryan <3's bomex
mastadulog's Avatar
nice cowgod
Old January 20th, 2005, 06:58 AM   #22
cowgodv6's Avatar
I cannot wait to install
I may wait till march cause there is no point to drop her now
Old January 24th, 2005, 08:02 PM   #23
Q
accord6's Avatar
ohh nice updates. did you get custom settings for the front springs?
i'm still not sure on what to get, d2 or tein coilovers.
Old January 25th, 2005, 05:51 AM   #24
cowgodv6's Avatar
I would not bother with coilovers, unless you have nice winter conditions, but here it's a real pain to remove the kit and put OEM shocks/springs every 6 months
I got S-Tech Springs and I am gonna drop it in march ( no time right now )
Old January 25th, 2005, 07:50 AM   #25
awesome Tell us when you do install it. And if can take some pictures Oh , maybe you can help me when I get mine
Old January 25th, 2005, 03:14 PM   #26
Q
accord6's Avatar
oh then the springs are regular settings for the I4?
Old January 25th, 2005, 04:50 PM   #27
bryan <3's bomex
mastadulog's Avatar
id try out the d2 coilovers. alot of people are raving about them
Old January 26th, 2005, 05:08 AM   #28
cowgodv6's Avatar
they are set for the weight of the car ... all CD5 or CD7
you can have these on the wagon - they weigh in @ 3200+ lbs or the I4
it's the compression rate the the spring that makes the "difference"
they are suppose to drop the I4 2.1 " and 1.8" in the rear
I'm hoping for a 2.2-2.4" drop with 2.0" in the rear
I'm gonna measure before and after to tell you guys exactly how much
maybe I'll install them early .. like this weekend cause I really don't wanna wait ... we'll see
Old January 26th, 2005, 11:07 AM   #29
bryan <3's bomex
mastadulog's Avatar
wow 2 inches youre a brave soul! take it easy on those inclines
Old January 26th, 2005, 11:25 AM   #30
cowgodv6's Avatar
wanna see a drop I use to have ?
stock height
3" dropped
