Shocks/strut for 95 Accord V6 - Honda Accord Forum : V6 Performance Accord Forums
Old June 6th, 2005, 02:12 PM   #1
I have a 1995 Honda Accord EX V6. I was planning to get Eibach pro springs for the 95-97 Accord V6. Even thought my car will only drop 1.4". That's alright because it gives me enough clearence to go through the car wash. I am looking to buy good shocks that will work with the Eibach springs. Anybody have any suggestions?
Som95ACCORD is offline   Reply With Quote Quick reply to this message
Old June 6th, 2005, 03:20 PM   #2
bryan <3's bomex
mastadulog's Avatar
im using tokico illuminas that i bought from omega, they ride pretty nice. kyb agx are also good . the prokits will lower your car more than 1.4" after they start to sag. its more like 1.75"
Old June 7th, 2005, 07:58 AM   #3
When getting shocks and lowering springs. Is it necessary to get camber kits? Also when the car is lower, will the car be able to get an alignment?
Old June 7th, 2005, 10:03 AM   #4
bryan <3's bomex
mastadulog's Avatar
no and yes
-97 Accord V6-
aim: bpdulog
photos:
myspace:
hincity:
Old June 8th, 2005, 08:54 PM   #5
youd want to get a camber kit. if not you will chew up tires within 2-3 months
cranberynvodka is offline   Reply With Quote Quick reply to this message
Old June 21st, 2005, 10:24 AM   #6
Shifting 5 Gears Baby !!
cowgodv6's Avatar
camber kits are needed if drops are 1.8" or more
less then that a negative camber will help you corner and it "will" cause more wear on the tire
I'm dropped on KYB GR-2 with Tein S Tech
the drop is sooo sick and the comfort is OEM comfort with a drop
I love it and so does everyone else I drive with
camber kit will be installed this weekend
Old July 14th, 2005, 12:14 PM   #7
So fellas I got my ride maintinanced... So now moving on to the Suspension.
Here is what I was looking at: Eibach Pro-kit for the V6 and pair those with some GR-2's and then get an alignment after they have settled and see if I need new cambers for better adjustment. This is going to run me about 500 with the Pro's and the GR-2's w/alignment at the local tire whole.
But looking at cowgodv6's ride is really where it gets tough. That is a sick drop. So I will through this out there... Which drop is gonna be more comfort mixed with handling and look? Also cowgodv6 how much where the Tein S Tech's?
Soelknight is offline   Reply With Quote Quick reply to this message
Old July 15th, 2005, 05:34 AM   #8
cowgodv6's Avatar
I picked them up for 220$ cdn
that's like 160-170$ USD
look on ebay, they have them all the time
Old July 15th, 2005, 12:34 PM   #9
I guess now I have a decision to make... I thought it was going to be simple but no...
Old July 17th, 2005, 09:34 AM   #10
what exactly do cambers do? and how much do they run for?
Tekron is offline   Reply With Quote Quick reply to this message
Old July 18th, 2005, 02:02 AM   #11
camber is the possition of the wheel and tire from exact perpendicular to the ground. When you move something down which puts pressure on the wheel it tends to kick the bottom out more then the top. and to correct this they change the camber(+ or -) to compensate for the change. if camber is not correct you chew tires up fast(uneven wear) and get bad gas milage as well as put un wanted stress on your other vital parts on the axels. if done right tho your tires will wear even and will last you longer then if you just slam your car and dont bother to do the right thing to compensate for the lowering.
There is a certain point tho that the stock camber can handle and from what i have heard is about a 1.5"-2" drop on our cars. but you go beyond this then you must drop another 100+ on a good quality camber kit to make everything happy.
Do things right the first time done half ass it.......
Powder11 is offline   Reply With Quote Quick reply to this message
Old July 18th, 2005, 04:25 AM   #12
cowgodv6's Avatar
exactly
I just installed my camber kit this weekend, with a new set of stabalizer bushings for the swap bar and new ball joints
feels nice and stiff ( no jokes about this )
as for the camber kit, it's good, but I hear a bit of noise when I have extension of the controller arm, metal on metal noise ( camber kit on controller arm )
I will think of something, like a poly shielding for it
and the set I bought - R-1 camber kit - front and rear ( rear is just longer bolts ) cost like 120$ shipped to me in canada, so for you guys, it'll be like 80$ and corrected 1.75-2 degree front
Old July 29th, 2005, 11:21 PM   #13
I'd go w/Yellows or AGX, I guess Illuminas could be thrown in the mix too. I like the adjustables for obvious reasons, the only drawback to the AGX is that the ride heights is not adjustable as with the Illuminas and Yellows. However, the AGX is by far the less costly of the three. I guess it all depends on how much money you have to throw at your suspension. Good luck.
04MonteLS is offline   Reply With Quote Quick reply to this message
