18s!!! - Honda Accord Forum : V6 Performance Accord Forums
Old October 20th, 2003, 10:04 PM   #1
18s!!!
hey every one ive been looking around for rims that is 18s and tires i want to know 215-45-18 will that fit right without rumbing??or 245-40-18s i live newjersey meaning alot of pot holes thans
accordboy is offline   Reply With Quote Quick reply to this message
Old October 20th, 2003, 10:08 PM   #2
youll probably be better off with 225.40.18s. its a more common size.
Old October 20th, 2003, 10:16 PM   #3
but on the sticky forum it says thats not right
Old October 20th, 2003, 11:14 PM   #4
v6p gangster
PFizzle's Avatar
thats what i have 225-40 18 zr yokohama paradas Spec-II on 18inch racing hart C5s
SHIFT_future
FEEL THE SKYLINE | DRIVE JAPAN 日本
Old October 20th, 2003, 11:19 PM   #5
i dunno, show me the sticky. ask most of us on here, id say 90% have the size me and pfizzle have, cuz its more common and better with pricing. a 215.45 tire is not as wide and a little taller. usually a 225.40 with a 1.5" drop fills up gap nicely without sitting too low.
Old October 21st, 2003, 12:56 AM   #6
its under stock vs aftermarket in the rims section http://www.miata.net/garage/tirecalc.html thats the page it shows and also on tirerack.com it says 215 45 18s 2
Old October 21st, 2003, 08:18 AM   #7
from what i can tell about that thing, its tryin to get you as close to stock sizes as possible, so the diameter of this wheel and tire package is about the same as the diameter of your stock wheel and tire package. i just did a tirerack search for your tire size, which brought back 5 options, the cheapest being $169 Bridgestone, using me and pfizzles size, you get 72 results with the cheapest being a $95 Kumho. if you dont want your speedo to change at all, still retain basically the stock height, and really nothing change, your size is fine, but much more expensive.
Old October 21st, 2003, 01:22 PM   #8
cool, thanks and do u get bubbles? since u live in tri state area? im just afraid of that because my friend was gettin bubble on wit 40s thats why i want 45 you know
Old October 21st, 2003, 01:24 PM   #9
yeah, the kumhos i have one bubble with a 40 series. i plowed into a pothole and that was that. i have toyos before this on another set of rims and no bubbles.
Old October 21st, 2003, 01:33 PM   #10
yeah man plus tirerack is mad conservative, they like to keep things as close to the rule as possible. so never mind them, 225/45 or 225/40 is what most guys on here roll, and if i go 18s thats what im gonna roll.
Old October 21st, 2003, 01:39 PM   #11
i go to the city all the time thats why im really worry about, and sometime i know i hit some pretty bad potholes too and i dont want it to rub i think 225 wit 45 will rub
Old October 21st, 2003, 01:49 PM   #12
if 225/45 has you so worried go with 225/40, it will give you a tad more clearance at the expense of a shorter sidewall, so then the pothole wont rub, they just bust your damn tire.
Dawg tons of cats role 225/45s no problem, hell tireack recomended i go 215/50 for my MDX 17s when i called to ask them if they could fit, just because the offset widened the track 5mm on each side. they are great people, but they are that conservative.
one thing i learned from them tho, make sure the load rating is 91 or higher for whatever tire you get especially if they are below 55 series, the AVR is pretty damn fat, so if you have a tire that is below the load rating, dont be suprised if one good pothole or manhole cover busts your tire. matter a fact try to get like 225/45/17 92, with the 92 being the load rating. also most people ignore it but be sure your speed rating is above 145mph, which is what Honda OEM tyres have. these two factors affect wheel performance and durability more than most people think.
Old October 21st, 2003, 02:11 PM   #13
i c i c... can 18x8 or 8.5 fit?? for the max is 7.5?? im checkin these rims out and not sure if it will fit the tire size is 225 40 18
Old October 21st, 2003, 02:30 PM   #14
someone told me on here that they have 18x8 with no problems, i was like i would'nt go that wide tho
but its all there man, do a search or browse the suspension forum.
eg.
http://www.v6performance.net/forums/...262&forumid=14
Old October 21st, 2003, 08:50 PM   #15
i c, thanks snikwad im still doing research so thats y im trying to find out before buyin rims now everything is hard 2 sell out if your brought something you dont want
Old October 21st, 2003, 09:06 PM   #16
