installing slr mirrors or any - Honda Accord Forum : V6 Performance Accord Forums
Old October 22nd, 2003, 10:20 PM   #1
Talking installing slr mirrors or any
hi boyz and girlz i just installed slr mirrors it took about 4 hours its my 1st time ,my car is power mirrors and i was with limit tools but all the tools you should need. 1 8mm socket rench, 2 flat head, 3 philps head, 4 electric tape or connectors, 5 wire cutters THATS ALL FOR TOOLS. NOW 1st thing to do is take all the screws out of da side panel, 2 use your hands and grap the side of the mirror triangle is (inside the car) and pull up towards you, 3 slow but got to use some strengh or use a flat head to pop open the panel the whole panel must be hanging off, 4 you have to take off the connectors to your oem, 5 take all the screws off with a 8 mm rench and cut the wires thats what i did, there will be a form thing or the rubber piece of the oem mirrors take that and use it on the new 1, 6 wire them up what ever color it goes with. 7 they will b a extention on the wires for you to took up on your "light up mirrors "driver side i just grounded it where the fuse box is at with the srs light, and passanger side grounded in the fuse box area too but with the 20a fuse for which one but its in the lower one your mirror will light up only if you have your keys turn on to the 2nd one but it will always be on now repeat it back, backwards and you have it set up,
accordboy is offline   Reply With Quote Quick reply to this message
Old October 22nd, 2003, 11:08 PM   #2
Pictures?
Crestgel is offline   Reply With Quote Quick reply to this message
Old October 23rd, 2003, 01:06 AM   #3
where your bolts on the mirros too short? my firend had a problem trying to install them im gonna take a better look on his someday
Old October 23rd, 2003, 11:44 AM   #4
sorry i for got to tell you go to home depot and get screws from there take 1 of the the screws and bring it in about 1 1/4 inch long and crestgel i dont have a digital cam
Old November 2nd, 2003, 09:27 PM   #5
Loneryder
docfnky's Avatar
Send a message via AIM to docfnky
docfnky is offline   Reply With Quote Quick reply to this message
Old November 5th, 2003, 05:04 PM   #6
Those mirrors look tight i seen em on ebay, They look kinna small in the pics though Compared to stock, Are they really small in real life???
Old January 23rd, 2004, 03:43 PM   #7
yeah the slr mirrors are smaller and i was kind of disappointed when i found out they didnt have a motor in them, but i think they look pretty cool.
I had a problem with the bolts being too long and I could hear the wind when i was going fast, but they are adjustable so I ended up getting a better fit.
The only problem I've had with them is that when I adjust my mirrors just right, after some driving they move from where I put them, but it's not too big a deal
gino31337 is offline   Reply With Quote Quick reply to this message
Old February 2nd, 2004, 01:09 AM   #8
Send a message via AIM to evahak311
my slr mirrors suck, i can hardly see when looking at them but my bolts were too short and i had to go to home depot and do a little hunting for bolts and washers.
evahak311 is offline   Reply With Quote Quick reply to this message
Old May 20th, 2004, 08:33 AM   #9
i'm gonna have to buy sum longer screws (not bolts but screws)
where you mirrors already threaded to accept bolts? (if i'm confusing you guys i'm talkin about where you bolt the mirror to the body of the car, the 3 spots)
98av6 is offline   Reply With Quote Quick reply to this message
Old May 20th, 2004, 09:06 AM   #10
original member!
Nittanys1's Avatar
for my M3 mirrors there were no threads in them....what I did was take out the three bolts in the factory mirror and put them in the other holes...i filled the holes with some compound that you have to mix together and it gets hard....then stuck the bolts in there making sure there was plenty of compound.....i had to wait about a day or two before i could install them....
SPONSORS:
Old May 20th, 2004, 09:33 AM   #11
New Member
aznfunkyflip's Avatar
Originally posted by docfnky
Old May 20th, 2004, 10:15 AM   #12
that would be the only way to do it?
Old May 20th, 2004, 01:32 PM   #13
original member!
Nittanys1's Avatar
well i think its the easiest way
Old May 20th, 2004, 04:58 PM   #14
k! so i understand you correctly ( cuz i dont' want my mirrors to fall off! lol)
fill up the holes with the compound stuff, let dry for a few days, then you screw the new screws into the compound right?
Old May 21st, 2004, 12:32 AM   #15
original member!
Nittanys1's Avatar
yeah you might want to rough up the surface on the inside of the tube(clean) before you use the compound
on another note, I went to home depot and got some (memory foam) weather strip and put it on the mirrors so the water wouldnt get in...if you take your time and lige it up you can get it to work pretty well...i found this out when i took them off for wireing
when you goto install make sure you take your time when you tighten the bolts. if you tighten the to fast they could possible break the seal you just made.
i have had my mirrors on for 7 months and havent had a problem
SPONSORS:
Old May 21st, 2004, 09:18 AM   #16
okay perfect! sound good, by any chance do you remember what the name of the compound was?
Old May 21st, 2004, 02:57 PM   #17
original member!
Nittanys1's Avatar
umm like jp weld or somthing...its two different tubes that you mix together for the hardining to start...goto homje depot and they will have alot to choose from....get something that works with plastic....
Old May 21st, 2004, 03:10 PM   #18
littlejuanito's Avatar
Originally posted by aznfunkyflip
double werd!
littlejuanito is offline   Reply With Quote Quick reply to this message
Old May 21st, 2004, 09:06 PM   #19
k thanks, i just wanted to make sure before i fix the mirrors cuz if it works for you it'll work for me!
k one last question for u, did ur m3 mirrors come with just 3 wires: red, white and black?
Old May 21st, 2004, 10:58 PM   #20
original member!
Nittanys1's Avatar
six a set for the power mirror and then one fore the turn signal
Old May 22nd, 2004, 08:22 AM   #21
k same here, you know how for our mirrors you need 3 connections to make it work properly? and these m3 mirrors one have the red and white connection, how did you get yours to work in all directions?
Old May 22nd, 2004, 09:29 AM   #22
original member!
Nittanys1's Avatar
i pluged them in and then tested the mirror controller...turned out i wired it wrong so i went back and switched the wires till everything worked right
Old May 22nd, 2004, 04:04 PM   #23
you had the red, white an black wire for the power mirror part right?
no more wires?
Old May 22nd, 2004, 11:47 PM   #24
original member!
Nittanys1's Avatar
i only had three for the power and three for the turn signals...i dont remember the color of the wires tho....
SPONSORS:
Old May 23rd, 2004, 09:56 AM   #25
k, that's what i have,
only problem i have right now is that there's 3 things u need to connect to for the mirror control, and i only have the red and white wire, (black goes to the ground in the harness)
Old May 23rd, 2004, 12:25 PM   #26
original member!
Nittanys1's Avatar
yeah hook them up to i think it may be a green and yellow or something...but whatever it is hook it up and try it...you should have had this done by now
SPONSORS:
Old May 23rd, 2004, 12:31 PM   #27
Old Member
Du3ce's Avatar
no pics up???
Old May 23rd, 2004, 08:56 PM   #28
lol i've already tried! i can get my mirrors to move down and to the right, but tried a bunch of times to get it to move up and left but no luck!!
Old May 23rd, 2004, 09:01 PM   #29
this is the wiring code i have:
Left mirror = Down/Up--> Blue/white
Left/Right---> Blue/orange
Right mirror = Down/Up---> Blue/white
Left/Right---->Light Green
Old May 23rd, 2004, 09:04 PM   #30
k that looks easy enuff, i'm prolly just doing it wrong or being impatient!
k i picked up sum jb weld stuff to fill up the holes,
so i rough up the holes, fill em in, it says the stuff will harden in 4 minutes, should i screw the screws in before it's hardened or after?
(by the way thanks for answering all my questions!)
