what fuse should i use? - Honda Accord Forum : V6 Performance Accord Forums
Old October 24th, 2003, 01:30 PM   #1
I have a 1400watt system and i dont know what fuse to use at the battery...2 amps each equalling 700 watts but dont run it max. The fuse just blew yesterday in the Cali heat. so what do you guys thinks?
NocturnalCoupe is offline   Reply With Quote Quick reply to this message
Old October 24th, 2003, 01:36 PM   #2
J32A2 6-Speed Rocks
Silv_Accord_V6's Avatar
Send a message via AIM to Silv_Accord_V6
use an 80 Amp fuse
Silv_Accord_V6 is offline   Reply With Quote Quick reply to this message
Old October 24th, 2003, 01:57 PM   #3
Old Member
Du3ce's Avatar
nah 100 atleast
Old October 24th, 2003, 02:09 PM   #4
8th World Wonder
GotVtec's Avatar
What are the fuse rating's on the amps?
Rule of thumb I went with when installing, was add up all the electrical fusing in the car and add some depending on the AWG of power wire.
GotVtec is offline   Reply With Quote Quick reply to this message
Old October 24th, 2003, 02:13 PM   #5
Old Member
Du3ce's Avatar
you should be using atleast a 2 or 0 gauge wire
Old October 27th, 2003, 11:48 PM   #6
Ok, what kind of system do you have? What gauge power wire are you running? Is your system 1400 watts RMS, or are you talking PEAK? If not listen to GotVtec, thats the easiest way.
Goodbread is offline   Reply With Quote Quick reply to this message
Old October 28th, 2003, 12:23 AM   #7
easy rule of thumb, add up the fuses on the amps and anything else connected and without a cap subtract 5%, with a cap add 5%
Old October 28th, 2003, 12:47 AM   #8
are you talking about the fuse under the hood or on the amps?
im using 150 amp fuse under the hood....and its never blown.
Old October 28th, 2003, 12:53 AM   #9
but if the fuse is too high it's worthless, you want it to be just over the edge of the max your amps can suck, so with the slightest opps the fuse blows and not your amps. I used to pop a 140a fuse every few months, but only on a real hot day, and only with a bass track with real long and drawn out bass. I put a phoenix gold breaker in, so now instead of pissing $5 every time it decides to pop, I just pop the hood, swing the lever back in, and away she goes, but I've only had to reset it once, and that was doing a test fit with my other DX700, I had one DX700 running each of my L7s, woohooo it was obnoxious, little too much for me though.
