how to hook amp to front speakers? - Honda Accord Forum : V6 Performance Accord Forums
Old October 26th, 2003, 10:58 PM   #1
EX-Featured Ride Coord.
DaBenz7898's Avatar
Send a message via AIM to DaBenz7898 Send a message via MSN to DaBenz7898
i'm a newbie when it comes to stereo stuff, so please bear with me....
i have a 2/3/4 channel amp which is currently hooked to my rear two speakers. the rear speakers are great, but they drown out the front speakers unless i adjust fader on my stock head unit. my question is, should i hook the extra 2 channels on my amp to the front 2 speakers in the doors? if so, how would i go about doing that without ripping my doors apart. i already took apart the doors when i put aftermarket speakers in. i really don't feel like doing it all over again. are there wires from the speakers that go near the front dash??
thanks.
DaBenz7898
Pics, mods, and latest updates:
** Click
** Click
DaBenz7898 is offline   Reply With Quote Quick reply to this message
Old October 27th, 2003, 08:57 AM   #2
If you have your stock deck... take out the deck.. and pickup a after market wiring harness at any local audio store for like $8. Use that as a guide to pinpoint which wires you will need to tap into as the wires that power your front speakers. Then pickup a Line-out converter and run that into your RCA inputs of your amp. Wire the speaker outputs back behind your stock HU into the stock speaker wires that run to your front speakers.
Sounds complicated... but it's not! Hollar if you need more help.
Old October 27th, 2003, 02:01 PM   #3
DaBenz7898's Avatar
okay.....makes sense...
anyone know which wires in the oem harness sends the signal to the front speakers??
DaBenz7898
** Click
** Click
Old October 27th, 2003, 02:19 PM   #4
PitchBlk, aka BigLou 7
Loulax07's Avatar
u wont need to know this
the wire harness adapter does all the work for u
u just solder the new radio's harness to the adapter harness, then plug in the adapter harness to the oem harness
Old October 27th, 2003, 04:48 PM   #5
DaBenz7898's Avatar
i don't have an aftermarket radio, its the stock in dash changer
DaBenz7898
** Click
** Click
