extreme problem..... - Honda Accord Forum : V6 Performance Accord Forums
Old October 27th, 2003, 01:19 PM   #1
ive got the 03 accord 6mt v6, i was installing a new set of subs after recently having an older pair in, i used everything the same way that i used with the old subs that worked fine, i had high level input converters connected to the back speakers, to the amp, the remote wire is wired to the acc fuse in the glove box, (this all due to the fuggin stock HU), and power run and everything, all worked fine b4, now right after i hooked them up i got a bad interference static noise from rear drivers speaker, so i disconnected subs and everything, then i turn on the radio and still, all i can hear is static, with a little bit of radio, and its turned all the way to 40!! sounds like its at 5?????? i checked all the fuses, and couldnt see any blown ones, the radio turns on, off fine, its not blown. but all i hear is the rear drivers side speaker, thats the only one that plays anything, and when i start the car and drive, i get the alternator whine through the rear drivers speaker, with static and almost no radio......what do i do??? did i somehow fug something up? i bought new 6x9's today and hooked em up, still same thing, static plays in new speaker....
PLEASE HELP ME IM GOING INSANE......
thanks
chris
cdurk5 is offline   Reply With Quote Quick reply to this message
Old October 27th, 2003, 01:27 PM   #2
PitchBlk, aka BigLou 7
Loulax07's Avatar
i say disconect everything u just connected, see if noise goes away
if so, install pieces one at a time till u figure what causes it
OR, start disconnecting things one at a time until noise stops
Old October 27th, 2003, 01:40 PM   #3
ya, i just disconnected the new speaker i installed, and everything turned off, i know honda likes to put relays in wierd places and chit which would explain why everything doesnt work if one speakers is not connected.....i am so lost, subs, amp everything not stock is disconected......
Old October 27th, 2003, 01:48 PM   #4
Loulax07's Avatar
with rear speakers not hooked up, which i had for a while, everything else still worked
Old October 27th, 2003, 02:08 PM   #5
ugh... it looks like you have a short circuit somewhere.. some loose wiring is grounding out somewhere... recheck every connection... especially the LOC, speaker outputs... g'luck!
Ugh I'm having alt whine creep back into my system as well.. I'll haveto temporarly use a loop-isolator until I get time to really find the problem... car audio issues never end
Old October 27th, 2003, 02:11 PM   #6
so all i have to do is check all my grounds? and i should be good?
thanks guys
chris
Old October 27th, 2003, 02:18 PM   #7
Loulax07's Avatar
no, check ALL connections
Old October 27th, 2003, 03:16 PM   #8
everything is still screwed up and i check every stock wire, i have no other aftermarket audio thing in there, now, my front speakers are playing and my rear passenger is playing and my drivers side is still static, and if i disconnect my drivers side everything turns off, and i have the radio at 40, still sounds like it is at 10....any new input?
Old October 27th, 2003, 03:23 PM   #9
Loulax07's Avatar
separate all wires, even if disconnected
may be a short somewhere
even tho u say u have no aftermarket thing in there, u still have wires run, check those
