Installation Done...Sounds Great! - Honda Accord Forum : V6 Performance Accord Forums
Old November 3rd, 2003, 09:59 PM   #1
Well the install went smooth. Took all day, and the only fix is to refasten the crossover on the driver side which came loose in the door panel. It rattles only when the door is closed hard. Mounted just behind the map-pocket on either door.
Sounds great. Not too, too loud, but the bass will hit you tightly and strong if the amp control is turned up. I have it set and still have lots of room to go should I need it
Originally I was going to have the amp control mounted where the fog light switch would be, but the controller was just a bit too big and had no room to shave or grind it down.
2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage Dual Pulley 2 & APR TCU Tunes | APR CPS | Technology Package | 490awhp/435awtq
pdqgp is offline   Reply With Quote Quick reply to this message
Old November 3rd, 2003, 10:24 PM   #2
Old Member
Du3ce's Avatar
sweet install i have the same sub except i have 2 12L5's
