headlight bulbs , please help - Honda Accord Forum : V6 Performance Accord Forums
Old November 8th, 2003, 04:58 PM   #1
import tuner and rn
eolife22's Avatar
i just bought some sugo racing halogen bulbs from ebay ,
anyway they are 130/100 w. is this safe for the harness in the high and low beam , thanks in advance
eolife22 is offline   Reply With Quote Quick reply to this message
Old November 8th, 2003, 06:15 PM   #2
Old Member
Du3ce's Avatar
theyre a little high get a wire harness
Old November 8th, 2003, 06:34 PM   #3
thread killer
yeah...that's pretty high output there
Old November 8th, 2003, 06:54 PM   #4
♠ 2009 Pontiac Vibe GT ♠
lowincash's Avatar
Send a message via AIM to lowincash Send a message via MSN to lowincash
i used to have 80W bulbs for my low beams and they were pretty hot. it turned the lil cap in front of the bulb brown and looks nasty. if you're gonna use anything over 80W you should get new harnessesses just to be on the safe side.
lowincash is offline   Reply With Quote Quick reply to this message
Old November 8th, 2003, 11:17 PM   #5
U R nutz, U cant use those bulbs with the stock Harnesses, If u did a Search u would know that, It will fry the S*** of your stocks, U need to Upgrade them if u want to put those bulbs in.........
Old November 9th, 2003, 08:11 AM   #6
import tuner and rn
eolife22's Avatar
trust me , i did a search , i dont like to waste people's time with stupid questions , anyway thanks for the input guys , going to get a harness right away
Old November 17th, 2003, 04:48 PM   #7
Just upgrade the harness to thicker wire. Those 130's will work just fine; Bright but fine.
<<<< is offline   Reply With Quote Quick reply to this message
