need help w/my DIY grill - Honda Accord Forum : V6 Performance Accord Forums
Old November 9th, 2003, 08:09 PM   #1
money + no time = Stock
Comptechjunkie's Avatar
Send a message via AIM to Comptechjunkie
so i cut out the center part of the grill and all, but there are those holes on the sides and in the middle. i know i have to use bondo to fill them in, but how do i fill these holes in, because if i used bondo right now it wold just drip out. do i just put like duck tape underneath and let the bondo harden? what should i do? osrry if that didnt make sence but i need help!!!
White '98 Accord ex V6
Back to Stock
Comptechjunkie is offline   Reply With Quote Quick reply to this message
Old November 9th, 2003, 08:23 PM   #2
sonnieeeeboi's Avatar
well..use like something to hold the bondo in like you said...cover up the back part until it dries and hardens
Old November 9th, 2003, 08:37 PM   #3
Old Member
Du3ce's Avatar
do u have a sedan? take some pics and instructions on how to do it, im interested.
Old November 9th, 2003, 09:48 PM   #4
Teirs's Avatar
Send a message via AIM to Teirs
I'm interested in what you did with the grill, the 2001 stock grill is so ugly, and its molded to the bumper, argh.
Teirs is offline   Reply With Quote Quick reply to this message
Old November 10th, 2003, 08:29 AM   #5
no i have a coupe,but ill tke soe pics and post in the DIY threads
Back to Stock
Old November 10th, 2003, 11:29 AM   #6
QUICK!!! someone Beer me!
frryy's Avatar
Send a message via AIM to frryy
because of my accident, I've had to go about making yet ANOTHER DIY grill
So i'll post pics of what I did later on when I get home.
But yea, the first time, I used Bondo and it was kinda difficult at first. But you're right...you should use something to help the bondo stay or stick in place. Tape isn't a bad idea, but i'm not sure since i've never tried it.
When I did it, I used some wire mesh that i held in place until the bondo that i applied to it hardened.
This second time around tho, I'm using this molding clay type thing. I think it works easier than bondo since its a putty type substance and you can mold it to whatever shape you want. It also hardens just as hard as bondo, if not harder.
ryan.
frryy is offline   Reply With Quote Quick reply to this message
Old November 10th, 2003, 02:12 PM   #7
frryy, if i send you my oem grill, can you make me one?
Old November 10th, 2003, 02:26 PM   #8
Old Member
Du3ce's Avatar
oh i thought you had a sedan because the grill is attached to the bumper on the sedan
2007 Accord EX-L V6
Old November 10th, 2003, 03:19 PM   #9
frryy's Avatar
for the amount of time and effort 1 grill takes me, I would probably charge you TOO much than you would want to spend. I now know how ID10T feels about the DIY grills
But yea, here's a pic of the side of the grille filled in with the putty.
need help w/my DIY grill-untitled-2.jpg
ryan.
Old November 10th, 2003, 03:27 PM   #10
yun
Cool
Hey Ryan, can you tell me where I can get the putty?
yun is offline   Reply With Quote Quick reply to this message
Old November 10th, 2003, 03:33 PM   #11
well, would u charge more than say...$40?
Old November 10th, 2003, 04:08 PM   #12
what kind of putty did you use??
Back to Stock
Old November 10th, 2003, 04:27 PM   #13
frryy's Avatar
You can get the putty at any Autozone or Pepboys. Its usually near all the Bondo.
most definately
ryan.
Old November 10th, 2003, 04:34 PM   #14
Hey Frryy ... What kind of grill or mesh do you use? and also how do you attatch it to the back? im thinkin about doing this to mine and getting rid of my Grill Craft Upper... Thanks
HondaV698 is offline   Reply With Quote Quick reply to this message
