Bulb number for clock light? - Honda Accord Forum : V6 Performance Accord Forums
Old November 14th, 2003, 11:12 PM   #1
Vimal (vee-mall)
KnightRyder's Avatar
i noticed that my clock light isnt working, does anyone know what the bulb number is for that light? thank you.
Old November 15th, 2003, 12:06 PM   #2
Vimal (vee-mall)
anyone
Old November 18th, 2003, 09:22 PM   #3
GO TO DA HONDA DEALER NEAR U and ask them
they should no
cuz mine burn n dey fix my 4 free
MadeInVietNam is offline   Reply With Quote Quick reply to this message
Old November 20th, 2003, 02:58 PM   #4
money + no time = Stock
Comptechjunkie's Avatar
Send a message via AIM to Comptechjunkie
yeah just go to the dealership, and they will have it... only 4 bucks and very easy to fix
White '98 Accord ex V6
Back to Stock
Comptechjunkie is offline   Reply With Quote Quick reply to this message
Old November 20th, 2003, 07:29 PM   #5
Instuctions by Blazin036
Originally posted by Blazin036 on May 5th, 2003 at 12:58 AM
You can easy replace it yourself. They sell the bulbs at radioshack for a 1.49. it come 2 in a pack # 7219 12 volts 60mA.
As for installing it. First remove the clock unit by placing a screw driver under the base of the clock and pry upwards. Then disconect the two wire harrnesses. Look on the back of the clock you will see a small black screw its on the side/corner. Turn it half a turn and it should come loose take it out then you will see the blub wired to it. If you notice that it makes it power conection by touching the plate on the base. now take some thing small like a fine screw driver or nail cliper and just pry the wires up and un ravel it from the base. Now reverse the order when installing the new blub but cut the extra slack off after you rerun the wires through the bulb base it makes it a lot easier. Then reinstall the blub holder back in to the base and lock the blub holder into the base. and replug the wire harnesses and reinstall the clock, and finaly set the time.
Though you should have searched first. This site has enough info already to cover all the basic things with our cars .
Old November 20th, 2003, 10:18 PM   #6
Teirs's Avatar
Send a message via AIM to Teirs
aww i spent 2.58 for the bulb at the dealer, sheesh i got so ripped, but i was happy to have my clock light up after over a year of it not working.
Teirs is offline   Reply With Quote Quick reply to this message
Old November 20th, 2003, 11:02 PM   #7
Vimal (vee-mall)
thanks guys, i got the bulb from the dealer and i just replaced it.
