How do I get the cluster out??? - Honda Accord Forum : V6 Performance Accord Forums
Old November 17th, 2003, 06:55 AM   #1
Trying to put in this chrome bezel i bought to go around the guages. I got the trim out an screws out that hold the cluster in, now what? It looks like the clear plastic doesn't come off. Is it ok to unplug the wires an totally remove the cluster? Help me out guys.
DigitalScorpion is offline   Reply With Quote Quick reply to this message
Old November 17th, 2003, 07:04 AM   #2
Yes, unplug the three harnesses and remove the entire cluster. Getting the clear plastic cover off the first time is ... well ... a *****, to be honest. Once you remove the 4 torx bolts, I used a combination of exacto knife and small flathead screwdriver to chip away at the adhesive and pry the clear piece away from the bezel. All I can stress is TAKE YOUR TIME! You will undoubtedly start doing a real good job and then (like me) get pissed off that it is taking more than 5 minutes and start to rush it. That's right about the time you try to pry off too big a piece and get a nice crack in the plastic face.
Oh yeah and when breaking the adhesive loose it sounds like you're cracking the entire plastic piece. Scared the hell out of me 4 or 5 times, just keep going slowly.
petjuli is offline   Reply With Quote Quick reply to this message
Old November 17th, 2003, 08:17 AM   #3
Oook, i'll try the "patience" method again lol. Thanks. But once that step is done, does plugging the harnesses back in cause any problem? Any lights stay on or anything like that?
Old November 17th, 2003, 08:51 AM   #4
The MASTER of RED ACCORDS
1SweetV6's Avatar
I didn't have to do anything like that. Just go home depo, you can get a set of "start" keys, like the hex, but a start. I got a nice set for about 8 bucks. Just take the cluster out, then remove the screwas in the back. I think I had to remove all of them & then it came apart. Then the plastic cover pop's off. I didn't have to do ANY cutting !!!
2000 Honda Accord V6 EX-L
Color: Red
Image Short Ram Intake
OBX Heat Shield for my Short Ram Intake
OBX Headers
Tanabe Hyper Medallion dual exhaust
DENSO Iridium IK16 plugs
B&M Super cooler Transmission cooler
Tein Coil Over Suspension system
Suspension Techniques Sway bars (F&R)
Neuspeed Strut bar (Front)
OBX Type-R Lower Bottom Brace (Rear)
JT AutoStyle Jt EVO 2 Front & Rear Bumper, and Side-Skirts.
JT Front Bumper Lips
Mesh Grills, Front & Back
Wings West 3 Piece Spoiler
TYC Modena Style Taillights
43% /22% window tint
17x7 TSW VX1ís Nitto 450's
Blue silicon hoses, Blue wire covers
Weapon R chrome overflow tank, blue top
Black and clear head light covers
Red Neon lights inside, 16 of them.
Red Neon lights outside, 4 under the car
Red/Blue lights on the hood/w Blue turn signals
Red lights inside (dome, door lights, map lights)
Carbon Fiber dash kit.
Carbon Fiber bezel
White Gauges w/2 red neon lights
Hella Horns
1SweetV6 is offline   Reply With Quote Quick reply to this message
Old November 17th, 2003, 09:14 AM   #5
Old Member
Du3ce's Avatar
its held in by clips look in the front and back and just pop it off
Old November 17th, 2003, 12:03 PM   #6
Well the job is done. Definitely a pain in the a$$. There were not clips an it didn't just "pop" off. I had to pry it very gently with flathead an a pick, an a heatgun. Came off eventually an set bezel in, then just touched up the edges wit super glue. Its good to go now. Thanks guys.
