Coupe Taillight - Honda Accord Forum : V6 Performance Accord Forums
Old November 20th, 2003, 09:23 AM   #1
Coupe Taillight
i just noticed last night that our rear park lights, are also worked in with our indictaor lights, the one in the upper part of the triangle, so when we indicate for a turn it just flashes. i was wondering can i just change the bulb to i a single contact bulb or whatever.
Then the upper part of the triangle is used solely as an indicator.
What do i ask for, and do they have LED bulbs to fit our taillights?
thanks for the help.
Old November 20th, 2003, 10:00 AM   #2
OK anyone
Old November 20th, 2003, 12:02 PM   #3
♠ 2009 Pontiac Vibe GT ♠
lowincash's Avatar
Send a message via AIM to lowincash Send a message via MSN to lowincash
are you saying you want the top part of the triangle to not light up? i think you can just get a single filament bulb for the signal part and they should come on when you indicate a turn. the 2nd gen tyc tailights uses amber bulb for the turn signal and it only turns on when you indicate a turn. i was wanting to do this too and put an amber bulb in it but then i'll have to have the top part of the triangle cleared.
lowincash is offline   Reply With Quote Quick reply to this message
Old November 20th, 2003, 12:11 PM   #4
a single filament bulb should do the trick... Or buy 2nd gen TYC's...
NauticaV6 is offline   Reply With Quote Quick reply to this message
Old November 20th, 2003, 12:44 PM   #5
yeah lowincash is right....cuz i explained it to him. Stock the upper triangle light is a dual filiment....go to auto zone and buy a single filiment bulb and it should just light up as the turn signal. if you buy an LED bulb it may look alot brighter than the rest of the lights and look odd.
Lowincash---- just get the clear single filiment bulb and you wont have to worry about clearing the light cuz it will be red. That is unless you just like amber.
Old November 20th, 2003, 01:06 PM   #6
lowincash's Avatar
^^yeah i like amber hehe but i need to find a way to clear that part if it's even possible.
Old November 20th, 2003, 01:19 PM   #7
Thanks guys, for the record though i hate them TYC lights, the only light i thought about doing was a clear light, and painting it red on the lower half so the upper part of the triangle will be clear.
but i changed my mind, since the LEDs are so bright, i might have to chnage all of them then. or just do the inner park light that are beside the reverse light, that way it will look like i have a european accord with rear fogs. i think im gonna definately do that one.
does any one know the part # for the single filament or even the original double filament bulb. i don feel like searching.
Old November 20th, 2003, 01:26 PM   #8
lowincash's Avatar
the turn signal bulbs we have now is 2057 and i think it's the same as the front signal (1157) so i think you can try the 1156 bulbs which are single filament. please correct me if i am wrong here
that's what i want to do too. how can i get a hold of some clear triangles?
Old November 20th, 2003, 01:30 PM   #9
I cant remeber who told me, but you buy them off like ebay or somewhere, ahh yes... www.procarparts.com i know these guys have them, or used to have them, they are pretty cheap, like around $50 then you just paint the lower half red, that what a couple cats on here have done. Thing is i dont remeber what the name or type of paint is, but just line it with a tape or something and spray it, it looks dope too.
Old November 20th, 2003, 01:35 PM   #10
lowincash's Avatar
ok thanks i see them. they're like 55 bucks for the two triangles. would you think it'll look good on a red coupe w/ the top part of the corner clear and have amber bulbs in them?
and as for the bulbs i checked and yes you can use 1156 bulbs for the signal so they only come on when you signal.
Old November 20th, 2003, 01:41 PM   #11
Sweet. dawg, 1156, im gonna get that and and get red LED bulbs for the inside taillights so it looks like a european accord.
as for the red/clear tailights, cmon yo, it will be dope on a red coupe, the member i asked had it in his sig for a while and he used silver paint for the strip on the trunk lid and the lower part of the triangle onhis silver coupe, and it wasd dope, so since your car is red, it would be ill, with all red escept the upper part of the triangle, especially if u go single filament like i want to. and clear lights in front, and clear side marker, that would be so ill, i can see it now, all lights are clear, except the strip on the back.
DOPE, do it man do it, and post pics.
Old November 20th, 2003, 01:50 PM   #12
Hey Lowin, are the bulbs for the other taillights the same part # cause i wanna know what type LED bulb to look for?
Old November 20th, 2003, 01:50 PM   #13
lowincash's Avatar
lol that'll be my next mod for christmas then!
but i'll have to get clear red paint and put enough layers to match the center strip since i'm leaving that piece. do you think i'll need clear coats?
Old November 20th, 2003, 01:53 PM   #14
yeah , im almost certain he said he did but a few layer on it.
Old November 20th, 2003, 02:11 PM   #15
lowincash's Avatar
which other tailight? if you want the single filament one it's 1157 and the stock (2 filament) is 2057
Old November 20th, 2003, 02:13 PM   #16
the stock dual one, i just want LED bulbs for the inner tailights, the inner lights on the Trunk lid
Old November 20th, 2003, 02:49 PM   #17
Re: Coupe Taillight
I have my tails like this... The top is only used for the blinker. All I did was put some electrical tape over one of the contacts, that is it.
Entcee is offline   Reply With Quote Quick reply to this message
Old November 20th, 2003, 02:53 PM   #18
Wow, you are the [email protected]^!n man, im gonna do that ASAP. save that cheese ya dig.
thanks. oh, how will i know which side to cover, do i just try both and see?
Old November 20th, 2003, 03:01 PM   #19
Yeah, just cover one up and plug it in and see if it is the right one, if not cover the other one.
Old November 20th, 2003, 03:03 PM   #20
sweeeeeeeeeeeettttttttttt
thanks man.
Old November 20th, 2003, 04:57 PM   #21
lowincash's Avatar
hey that's just like how you do the front signal lights huh good idea
Old November 20th, 2003, 08:36 PM   #22
another way to make your tail look different is using nite shades and tinting it a little bit. it gives it a smoky-clear look, i did it on my tails and i think it looks pretty good.
ballaticious is offline   Reply With Quote Quick reply to this message
Old November 21st, 2003, 08:13 AM   #23
Hmm, ill look into the tint thing. so Lowin, you think i should do the front ones two, well naw, im kinda liking the way it loks with the side and the strip lit up.
Old November 21st, 2003, 11:03 AM   #24
lowincash's Avatar
for my front i only have my corners light up and i took out the bulb in the strip but it's still kinda lit up a lil cuz the hids goes thru it a bit. looks cool like that
Old November 21st, 2003, 12:27 PM   #25
naw i like the strip, i have my blacked out lights in my room, but when i take the bumper off to install my tranny cooler im gonna put them on. But the more i look at the stock lights, the more i like them.
Old November 21st, 2003, 12:29 PM   #26
SiLvAaCCoRdV6's Avatar
Send a message via AIM to SiLvAaCCoRdV6
just do what entcee said...thats what i did. Well instead of using tape i just pulled out the contact. Its, easy and saves you money. Yea u should put some clear coat on after u paint cause it will help prevent the paint from fading.
heres a closeup if anyone is wondering how i did the lights
2000 V6 Accord Coupe EX
NO MOD LISTS ALLOWED IN SIGNATURES!
click on
in the bottom to check out my pics
SiLvAaCCoRdV6 is offline   Reply With Quote Quick reply to this message
Old November 21st, 2003, 12:54 PM   #27
Yow Lowincash, here is da Man, Silvaaccordv6, he's the dude i asked. look at that $h!t. man your ride is dope SilvaAccordv6.
Old November 21st, 2003, 01:10 PM   #28
thanks snikwad.... I finally got my windows tinted and some custom exhaust, from the Y-pipe back. I'll get some pics up when i get my camera back
Old November 21st, 2003, 01:19 PM   #29
lowincash's Avatar
oh yea sivlaaccordv6 didn't i pm you about that lol
what do you mean you pulled out the contacts instead of using tape?
Old November 21st, 2003, 03:18 PM   #30
Here are some pics of my half-smoked stock lights. i followed the DIY for smoking tail lights in the DIY forum. I am happy with the outcome.
w3accord is offline   Reply With Quote Quick reply to this message
