Line Level Signals anywhere? - Honda Accord Forum : V6 Performance Accord Forums
Old November 20th, 2003, 09:38 PM   #1
1999 accord EX V6
1999accord's Avatar
Post Line Level Signals anywhere?
I am considering wiring my pda so that its sound comes out of my stock car audio system. Is there any line level lines that I can tie into? Where? I have the factory single CD player/tape deck and radio in a 1999 Accord. I am planning on having a switch so that either the signal from the PDA is being amplified or whichever signal I am substituting is transmitted. I am quite capable of doing this, I just need to know if and where the line level lines are. I am just going under the asssumption that the tape deck and CD put out low line level signals to some type of amplifier somewhere (like maybe in the radio unit). If I need to put in a cassete with the tape removed to fake out the system that wouldn't be so bad, or perhaps jumpering the circuit in the deck with a toggle switch. Has anyone done anything like this?
1999accord is offline   Reply With Quote Quick reply to this message
Old November 23rd, 2003, 07:31 AM   #2
1999 accord EX V6
1999accord's Avatar
Hello? Anyone?
Old November 23rd, 2003, 07:03 PM   #3
sorry buddy.. we dont have TLs.. where a seperate EQ system taks in a low level output from the CD player(pre-03). The accords have a built in amplifier in the cd player unit... if you have the specs on that you could tap into it that way... but goooood luck.. I couldnt find that circuit specs from matsu****a.. so I didnt bother with it... perhaps there could be a way to use the CD-changer controls as your line level input... if you can grab a wire harness that goes into that plug for the cd changer.. theer should be a pair of wires.. for the line level input from the cd changer unit... you could splice that into the line level output of your PDA.. just a thought...
other wise.. uh.. parallel LOCs in series to the high outputs? LOL nah that wouldnt be feasable.. given the fact.. anyways.. good luck
