Where can i get this - Honda Accord Forum : V6 Performance Accord Forums
Old November 21st, 2003, 10:34 AM   #1
Unhappy Where can i get this
I have the subs, the box, the amps, but i a converter that steps down the speaker level signal from my HU to a line lvel so i can feed it into the amps, i refuse to change my headunit, i want everything to look stock. but i do not want to feed speaker level inputs into the amp since they carry so much noise.
Does anyone know where i can find one of these line level converters, if thats the correct name.
i have a 1000w amp, and if all goes well i may add another with about 400w. i want to have eveything before i start, and this is a major part of the system i have planned.
Help please
Old November 21st, 2003, 10:44 AM   #2
Old Member
Du3ce's Avatar
i have one for sale look in the for sale forum 15 bucks shipped, it has 4 wires that connects to the HU and it has 2 holes to plug in ur rca to lead it into ur amp
Old November 21st, 2003, 11:00 AM   #3
www.davidnavone.com
Old November 21st, 2003, 12:18 PM   #4
four wires? the HU uses one of them plug things, where would these wires go? is it just one pr of RCAs or 2 prs.
Old November 21st, 2003, 12:36 PM   #5
Old Member
Du3ce's Avatar
theres a total for 4 wires you connect 2 of those wires to your left speaker, and use the other 2 to connect to the right ones. Theres a rca female output that you can plug in and that feeds into ur amp
Old November 21st, 2003, 12:37 PM   #6
Old Member
Du3ce's Avatar
if you want to see pics go here: http://www.v6performance.net/forums/...threadid=16451
Old November 21st, 2003, 01:02 PM   #7
Du3ce i still dont understand, in the thread someone asked if you have to splice the factory wire, but imnot sure what your answer meant, splice into the wire, or just plug it in. I'll buy it from you if u explain the hook up and the adapter, i really dont want to have to splice it though.
Old November 21st, 2003, 05:02 PM   #8
L_fty, peem my PM i sent you
