12V Connection for CVA 1006 - Honda Accord Forum : V6 Performance Accord Forums
Old November 25th, 2003, 12:22 PM   #1
What is the best way to connect the 12V supply for the CVA 1006 monitor and the brain unit. Can someone explain the battery cable connector in the picture. What is it and where can I get one?
Thanks,
Bhavin
Bhavin is offline   Reply With Quote Quick reply to this message
Old November 25th, 2003, 12:28 PM   #2
well from the size of the wire and fuse and whatnot, the thing pictured is for a system in the trunk, not just for the little CVA-1006. The power for that can just tap into your radio power line or anything else that will be on as soon as the car is on.
Old November 25th, 2003, 12:34 PM   #3
8th World Wonder
GotVtec's Avatar
You will need a wire harness to that plugs into the CVA wires and your OEM wire harness. There is a wire that carries the 12V current that plugs in-line with the fused pack in the CVA harness.
GotVtec is offline   Reply With Quote Quick reply to this message
Old November 25th, 2003, 12:50 PM   #4
Is the wire harness a direct fit that will connect the Supply voltage, illumination, speakers, etc... from the OEM harness to the CVA-Brain unit harness (Where can I find this?)? Or do I have to build my own?
Old November 26th, 2003, 01:10 PM   #5
PitchBlk, aka BigLou 7
Loulax07's Avatar
the harnesses are made by Metra
look here
http://incolor.inebraska.com/weisina...er/70-1721.htm
