DIY Grille for the 98-00 Coupe - Honda Accord Forum : V6 Performance Accord Forums
Old November 26th, 2003, 11:16 PM   #1
money + no time = Stock
Comptechjunkie's Avatar
Send a message via AIM to Comptechjunkie
HOW TO: DIY Grille for the 98-00 Coupe
Ok, Iíve looked all over the forums and I have not found a DIY for this. People have requested it so ill post it.
What you need:
ē Hack Saw blade or a dremmel tool or something to cut
ē Duck Tape
ē Fiberglass mat
ē Body filler or Bondo and hardener putties
ē Body Putty
ē Popsicle sticks or something to spread the bondo evenly
ē Rough sand paper (like 220 grit) and Very fine sand paper (like 1000 grit)
ē X-acto knife (not a must)
You can find all this at Pep-boys or something like that; Wal-mart has a lot of it.
First Step-
You have to take out the Grille (you can go to the DIY black out headlights to learn how to take off the bumper) There are 3 or 4 screws at the bottom of the grille once you take off the bumper. Take those out, along the three clips on top of the grille and itíll slide out.
Now you need to cut out the center section. You will need a hack saw blade or something small to cut this out. Cut along the bottom of the inside of the grille to get center out. Youíll figure it out. Heres a pic of where you should cut.
Step two-
Now that you have the center out, you will have 2 holes on the side and a gap in the middle. You will also have some bumps from those little tabs in the middle. Try to smooth or cut those holes and bumps down to the same level as the surrounding area with a dremmel or the same thing you used to cut out the center.
Step three-
Ok now for the fun part. People have a few different ways of doing this so there might be easier ways that I donít know about or havenít tried.
You will need to back the holes in the grille with duck tape or something that will let the Bondo stay on one spot. You can back these holes up with some fiberglass matting
Now that you have backed up the holes, its time for the bondo. There are directions on the package that shows you how to mix it, but if you are mixing a small amount of it make sure that you donít use too much hardener or itíll dry pretty fast.
Get a glob of the bondo a put it on the holes. Smooth it down so you wont have to do as much sanding/cutting.
Step four-
Time for sanding. If your bondo is piled high, you can use an x-acto knife to shape it. Now that you have done that, use your rough sand paper and just sand your heart out. Try to sand as smooth and even as the area around it.
Once you have done this, there will probably be some holes and other ugly spots you canít sand out. You can use the putty to fill in the holes/spots. Wait for the putty to dry and sand it down with sandpaper again.
Now that you have the holes filled in, you can use fine sand paper. I wet sanded all of the spots and got a real smooth finish.
This is not the easiest thing to do, and I will not be held responsible for what happens. If you mess up, just break or sand off the bondo and start over. If I missed some steps PM me or reply and ill add them. its been a long and tiring day and i couldnt sleep so i posted this, so more than likely i missed some steps
Here are some pics of the finished product and some of the process.
Im not finished painting it, but thats what i have right now for the time being.
White '98 Accord ex V6
Back to Stock
Comptechjunkie is offline   Reply With Quote Quick reply to this message
Old November 26th, 2003, 11:26 PM   #2
Nice! Can't wait to see the finished pics.
AjIsDope is offline   Reply With Quote Quick reply to this message
Old November 27th, 2003, 12:10 AM   #3
Very nice!! I think i might try that with my old grille/.
str8bklam is offline   Reply With Quote Quick reply to this message
Old November 27th, 2003, 01:22 AM   #4
AV6 OG
HIREN's Avatar
Send a message via AIM to HIREN
damn, that just seems like wayy too much work
the 5th gen accords and 6th gen civics have it easier, the outer peice of the grillle is just screwed on! so you can attach mesh to it and attach it back on
i just attached some mesh to my bumper with some ties, looks good and its time and cost effective!
2000 AV6 - Sold
14.86 @ 92.44 n/a
[email protected] 75 shot
2004 STi
[email protected]
2010 335d
[email protected]
HIREN is offline   Reply With Quote Quick reply to this message
Old November 27th, 2003, 08:42 AM   #5
you dont have to take off your bumper, but its hard to screw the screws back in wit the bumper on
Back to Stock
Old December 5th, 2003, 01:31 AM   #6
QuizWORX's Avatar
Which place can we buy those aluminum screens or mesh screens. Is there a place that we could buy this thing with different variety such as honeycomb mesh screen.
QuizWORX is offline   Reply With Quote Quick reply to this message
Old December 5th, 2003, 07:08 PM   #7
Home Depot have a 3'x8' screen like that for $3 near the tar for roofing.
98vtech is offline   Reply With Quote Quick reply to this message
Old December 5th, 2003, 11:45 PM   #8
better known as gutter guard
Back to Stock
Old December 6th, 2003, 01:36 AM   #9
AV6 OG
HIREN's Avatar
naw the gutter guard stuff that comes in a roll sux, its so small and too loose, it bends real easy, i had that at first, and got rid of it
I used a sheet for my current grille, really tough **** which is pretty damn hard to bend, I got it from a stucco guy who used it to bend around a pole to hold the cement before he stuccos it.
2000 AV6 - Sold
14.86 @ 92.44 n/a
2004 STi
[email protected]
2010 335d
[email protected]
Old December 6th, 2003, 09:39 PM   #10
got a pic?
Back to Stock
Old December 14th, 2003, 04:25 PM   #11
Senior Member
driven's Avatar
looks good.. why not just buy the type r one on procar parts for 40$ for the same effect? -Jai
Old December 14th, 2003, 04:49 PM   #12
are the grilles from procarparts.com black?
Old December 14th, 2003, 05:53 PM   #13
AV6 OG
HIREN's Avatar
Originally posted by Comptechjunkie on December 6th, 2003 at 09:39 PM
got a pic?
I'll try to take some pics soon
2000 AV6 - Sold
14.86 @ 92.44 n/a
2004 STi
[email protected]
2010 335d
[email protected]
Old December 14th, 2003, 10:55 PM   #14
Senior Member
driven's Avatar
yes.
Old December 15th, 2003, 02:45 PM   #15
Your V12, My V-twin.
JonHsiung's Avatar
When I still had my stock bumper I did the same thing but I fiberglassed the sides that got cut off, sanded it all down and bondo'd over it. It makes sure the bondo doesn't get all jacked up when it flexes because hand-laid fiberglass sheets fills in gaps better.
Anyway, yours looks absolutely gorgeous! $40 well saved (not to mention it fits like OEM - because it is!)
2000 AV6 Coupe
- J O N -
Old January 13th, 2004, 03:41 PM   #16
i just did a grill for a guy and i used fiberglass and then bondo then teh putty and it flexed without cracking, so i also recomend using fiberglass too
Back to Stock
Old February 17th, 2004, 09:26 PM   #17
V6P OG
LaoStradamus's Avatar
Send a message via AIM to LaoStradamus
i will never attempt this DIY again...but it was well worth it
LaoStradamus is offline   Reply With Quote Quick reply to this message
Old February 17th, 2004, 09:40 PM   #18
yeah im using Bondo brand fiberglass kit as we speak, and my step dad is bringing me some kind of putty tomorrow. the fiberglass is defintiley hardening, but being that it was my first time, the surface is not as as smooth as i want it to be.
Old February 19th, 2004, 01:02 AM   #19
Send a message via AIM to 00EXCoupe
I used a much easier method to make a custom grille. Using a sheet of mesh from APC which cost me $25 i first made a cardboard template. Then i cut out the mesh which was real easy only needed normal scissors and bent the top over the bar where the OEM grill clips in on top. Two screws with washers drilled into that bar keep the mesh well anchored and could easily be anchored on the bottom by drilling some holes and using zip ties. I'll have pics of it soon. It only took me about 20 minutes to do and i am very pleased with the results except i ****ed up one of the corners, oh well.
00EXCoupe is offline   Reply With Quote Quick reply to this message
Old February 19th, 2004, 01:45 AM   #20
AV6 OG
HIREN's Avatar
I had done kind of the same thing but with hard mesh
pic
http://www.imagestation.com/picture/...7/f9e9931a.jpg
http://www.imagestation.com/picture/...f/f9e9939c.jpg
the bottom isnt attached in the pics which is why its sticking out on the sides
anyone want them, i still have them for sale
2000 AV6 - Sold
14.86 @ 92.44 n/a
2004 STi
[email protected]
2010 335d
[email protected]
Old February 26th, 2004, 07:50 PM   #21
where can you get this fiberglass stuff whats it called?
M1ke is offline   Reply With Quote Quick reply to this message
Old February 20th, 2005, 03:11 PM   #22
4.0L
VietNinjaJ30A1's Avatar
pic
is that a sedan you cleared the grille out of?
Old February 20th, 2005, 07:36 PM   #23
AV6 OG
HIREN's Avatar
It's a coupe.
BTW, a year later they're still for sale! I have them sitting in storage.
Old February 21st, 2005, 06:13 PM   #24
wow this is weird... i was looking at the date and i thought that the posts were like last week, but it was last year lol thats funny
