Stock Radio problems!!!!! - Honda Accord Forum : V6 Performance Accord Forums
Old November 30th, 2003, 12:39 AM   #1
i was just listening to cds on my stock 6-cd changer when suddenly the screen read "ERR" .... then none of the cd's worked. could not even eject or load any cd's!! radio works fine but the cd player is the problem. whenever i push the "CD" button the screen continues to read "ERR".
to "correct" the problem i tried disconnecting the battery to reset the entire radio with hopes of bringing the cd- changer back to normal. i disconnected, put the radio code in and now it seems to have gotten worse.
now after resetting the radio, when i press the "CD" button it does not even do anything. nothing what so ever.
this is a serious problem. sum1 please helpppppppp!!!
tommy_touch is offline   Reply With Quote Quick reply to this message
Old November 30th, 2003, 02:22 AM   #2
V Go SoCal Drivers V
bustedryde's Avatar
There was actually a TSB on this problem, I had it on my 01, and they replaced it for free under warranty.
Old November 30th, 2003, 02:51 AM   #3
I HAVE TO GO TO THE DEALER TO REPLACE IT NOW?
AND WILL THEY SAY ANYTHING ABOUT ANY SOUND SYSTEM MODIFICATIONS?
Old November 30th, 2003, 04:34 AM   #4
___
borinka99's Avatar
you can try to take it out and unscrew the front part and see if the discs got jammed.
borinka99 is offline   Reply With Quote Quick reply to this message
