Adding Lights to your interior...w/fading option - Honda Accord Forum : V6 Performance Accord Forums
Old February 12th, 2009, 09:09 AM   #1
6th Gen Fanatic
Send a message via AIM to Nismode
Lightbulb Adding Lights to your interior...w/fading option
I've searched to no avail. Basically, I've seen pictures of members adding these lights bars (from threads like these) to their footwells, trunk, license plates, etc. I've even seen someone try to wire their map lights to the ceiling lights (like this old thread).
What I'm trying to find out is if it is possible to wire these additional lights to the dome light that fades in/out on lock/door close.
For example, to have the light tubes in the footwell turn on with the dome light when the door is opened, and fade back off when it is closed. And if wiring the map lights to the ceiling lights is also possible.
Nismode is offline   Reply With Quote Quick reply to this message
Old February 14th, 2009, 04:13 PM   #2
the cheapest way i could think of is 97 crv has a separated ignition key light module it would not fade in however would fade out after approx. 10sec. i believe this part is quite easy to pick in junk yard.
Alan 2001 is offline   Reply With Quote Quick reply to this message
Old February 14th, 2009, 04:29 PM   #3
6th Gen Fanatic
Actually, fading out would be the only thing I'd want. If fading in is too much of an issue, then so be it.
Old February 14th, 2009, 04:38 PM   #4
THLA 2009 Bombsquad
Dtownz Thrillah's Avatar
Just wire it to your dome light.
Im not sure if CCFLs can fade in and out [the have their own fade when they turn off though and it lasts like 2 1/2 seconds]
I had some puddle lights wired to my dome lights and they faded with my dome light.
Old February 14th, 2009, 04:40 PM   #5
Fast at Last!... kind of.
Steverino's Avatar
CCFLs don't fade, LEDs don't either.
Steverino is offline   Reply With Quote Quick reply to this message
Old February 14th, 2009, 04:40 PM   #6
6th Gen Fanatic
Where/how would I wire it? How did you wire your puddle lights?
Old February 14th, 2009, 04:42 PM   #7
THLA 2009 Bombsquad
My led dome light fades =]
Old February 14th, 2009, 04:45 PM   #8
THLA 2009 Bombsquad
I had to take down the headliner to get to the wiring of the dome light.
My puddle lights were tucked in the side skirt and then up the fuses boxes on each side of the car then behind the front pillars then ran above the headliner and I just spliced the wires to the positive and negative wires and put the headliner back in place.
I took off the puddle lights cuz they were amber instead of white and im not VIP enough haha
Old February 16th, 2009, 08:53 PM   #9
yeah leds can fade my dome light does
madaccord is offline   Reply With Quote Quick reply to this message
Old February 16th, 2009, 09:18 PM   #10
v not some model, my girl
99v6sedan's Avatar
puddle lights are supposed to be wired to the dome light?
Old February 16th, 2009, 09:19 PM   #11
6th Gen Fanatic
Not necessarily, but I wanted them to fade out with the dome light.
Old February 16th, 2009, 09:46 PM   #12
THLA 2009 Bombsquad
I wired mine to my dome light and they turn on when I unlocked my car. They turn on when I leave my car and fade off or if I hit the lock button they instantly turn off.
Old February 16th, 2009, 10:27 PM   #13
6th Gen Fanatic
They turn on when you leave the car?
Old February 16th, 2009, 10:43 PM   #14
-Maninder
^lol...
Old March 9th, 2009, 04:34 PM   #15
Red Over Grey
SilverHonda2007's Avatar
Send a message via AIM to SilverHonda2007 Send a message via Yahoo to SilverHonda2007
I just bought some LED's and from Sylvania web site they say the 7443 size will work for the map and dome light? Has anyone gotten the 7443 for map and dome for a honda accord coupe 2007.
SilverHonda2007 is offline   Reply With Quote Quick reply to this message
Old March 9th, 2009, 04:49 PM   #16
THLA 2009 Bombsquad
They sure did haha
When I open my doors they turned on and when I closed the doors they would stay on for like a couple of seconds and then fade off with the dome light =]
Old March 9th, 2009, 10:30 PM   #17
4.0L
VietNinjaJ30A1's Avatar
LEDs don't either.
Mine do. I have a bunch of 3mm LEDs soldered together (ghetto style) and I replaced my interior lights for ****s and giggles and they fade out like they're supposed to. I have them in my map lights, door lights and dome light. I just figured out the correct number of LEDs to use to make 12V safe and I soldered them together and plugged them in.
