cl-s seat swap help!! - Honda Accord Forum : V6 Performance Accord Forums
Old March 6th, 2009, 09:30 AM   #1
i got a deal on a set of front acura cl-s seats and i'm trying to do the swap. now we all know they bolt right up but the passenger side seat is power and the factory accord coupe seat is not. that's no big deal right now. my problem is the i can't decipher the harness. it has lots of wires like a cd player and its got me stumped . has anyone sucessfully completed this swap or know where i can get the wiring diagram for free? any help would be appreciated.
fasteddie15 is offline   Reply With Quote Quick reply to this message
Old March 6th, 2009, 10:47 AM   #2
Growth Chart Specialist
Shenaniganz08's Avatar
Originally Posted by fasteddie15 View Post
] now we all know they bolt right up
Since when?
Old March 6th, 2009, 11:55 AM   #3
well the cl-s seats bolt right up in my car. i appreciate you helping me out; oh yeah, all you did was ask another question that has nothing to do with my post. thanks. can anyone else give me actual help instead of sarcasm that is unneeded?
Old March 6th, 2009, 01:55 PM   #4
4.0L
VietNinjaJ30A1's Avatar
^^ chill out, man. To this day I don't think anyone on V6P has taken a set of CL-S seats and tried to bolt them into an Accord V6, so no, we didn't know that they bolt right up.
As far as the wires, go to the Acura dealership and see if you can find someone (usually a tech) who is nice enough to get you a pin-out diagram. That's what I did when I swapped my shifter assembly and I had to figure out which wire controlled which shift lock solenoid. I'm assuming the CL-S will have power, ground, and also input(s) for the seat heater. Only the Canadian Accord has seat heaters, so you may want to look into that harness to see if they match up.
Old March 6th, 2009, 10:17 PM   #5
Wow I asked an honest question, its not like its common sense/very common to see people with acura cl-s seats in their cars
Then again this is coming from someone who paid for a used transmission with 121K so a rational argument might not be possible
Old March 8th, 2009, 09:52 PM   #6
funny how that tranny i paid for runs with no probs at all. a deal is a deal and maybe if you spent less time trying to throw salt at someone you know absolutely nothing about you could actually find deals like me. not one for "internet thugs" so just grow up and try to do better.
Old March 8th, 2009, 10:32 PM   #7
chiefy's Avatar
peace be with all!!! 1st time hearing about this swap.. but good to know they bolt right up... check haynes manual for wiring diagram and see which wire does what but as VietNinjaJ30A1 said power ground and heat is for sure!
spool or be schooled!
Old March 9th, 2009, 05:06 AM   #8
3.2 Type-S 6spd
Type JDM's Avatar
I picked up some black cls seats tried to figure the wiring and gave up.
But you are correct they do bolt right up on all for brackets.
Too many wires side air bag, seat heaters,etc.
Type JDM is offline   Reply With Quote Quick reply to this message
Old March 9th, 2009, 09:26 AM   #9
4.0L
fasteddie15 - can you tell us how many wires there are coming from the seat harness?
Also, the side airbag connector should be completely separate...and yellow. I can only imagine there being 3-4 wires. Power, ground, and one or two going to the seat heater switch.
Old March 9th, 2009, 10:31 AM   #10
hmmm what next?
shonda1989's Avatar
wow this thread started with a bang
Old March 9th, 2009, 10:53 AM   #11
Dude you were the one being a jerk
Let's just drop it
Post a picture of the connector / pics of seats / pics of rails
we should be able to help with that info
Old March 10th, 2009, 07:40 AM   #12
i will hopefully be posting a pic later on of the harness. it has like 20+ wires coming from it; compared to the 6 from my factory power seat harness. maybe i'm over my head but i'm gonna give it my all. shoot, i paid good money for those seats, lol.
Old March 10th, 2009, 09:56 AM   #13
4.0L
I don't have the specs on the CL-S harness...but if it's set-up anything like the Accord, there should be a bunch of wires that split off into different connectors to be plugged into the seat. You probably don't have this harness, so I'm going to assume you only have the connectors that are attached to the seat/motors/heaters.
First of all...is your Accord driver's seat 8-way adjustable or 2-way? Is your Accord passenger seat power or manual?
My Helm's manual is showing that there should be a 6 pin connector for each heater switch, and then a 3 pin connector for each heater. This is for the Accord, so it may not help you with the CL-S seat at all, but it might.
Old March 15th, 2009, 01:51 PM   #14
Touch of CLaS
importtigger's Avatar
Send a message via AIM to importtigger
Look bro, I have had the cl-s seats in my av6 coupe for 2 years now all you have to do is leave he airbags unplugged and on the acura wiring diagram take all units that have power or are supposed to go to a fuse and give them constant power all that need ground, ground them. I think there are 4 powers and grounds per seat for forward, back, up, down. I may be mistaken as it has been a couple years since I wired them up. I didnt mess with the seat heaters, but I hope this info helps
importtigger is offline   Reply With Quote Quick reply to this message
Old April 12th, 2009, 08:52 AM   #15
RDuke's Avatar
Good luck
RDuke is offline   Reply With Quote Quick reply to this message
Old April 14th, 2009, 02:24 PM   #16
4.0L
Any update to wiring these up correctly? I think it's pointless to put these seats in you car if you're going to lose the side airbags and seat heaters. In that case...I'd just get Accord Coupe seats. Let us know if you found a wiring diagram for the seats!
Old April 14th, 2009, 03:00 PM   #17
nOrcaL7thgen's Avatar
Are cl-s seats worth all the trouble? I don't recall them being that much better...
nOrcaL7thgen is offline   Reply With Quote Quick reply to this message
