Navi Retrofit - Honda Accord Forum : V6 Performance Accord Forums
Old March 11th, 2009, 10:53 PM   #1
Navi Retrofit
For different navi versions and navi wiring diagram please refer to my other thread
http://torontoaccords.com/viewtopic.php?f=20&t=57437
Required Stuffs for Retrofitting CR-V Navi Unit with Civic Amplifier on 98-02 Accord
1. Metra Harness # 70-1721 OR Similar from CanadianTire/ Walmart
2. Antenna adapter Metra Harness # 40-HD20
3. Cassette player attachment kit for external amplifier
V6 08B12-S87-100
others 08B12-S84-100
4. Misc.
-eg wires, self-striping wire splice connectors, heat shrink tubes, solder essentials (40+ points)...
-optional: Cat5 cable to lengthen signal wires
5. Diagram
6th gen Radio pin assignment
Driver side fuse box harness distribution
6. Patient
Installation
1. Instruction of how to remove audio panel and installing attachment kit
http://www.handa-accessories.com/acc...cassetteex.pdf
Anger index
2. Placement of the external amplifer
-bend the amplifier bracket(one with fused nuts) inward abit (left side of the pix below
-enlarging screw hole on cassette player bracket.
-tighten amplifier to the cassette player bracket.
-use 3M double-side foam tape sticking between the cassette player bracket and right underneath of the amplifier.
Anger index
3. Wiring.
-matching wires from Metra plug to navi connector A accordingly
-matching wires from navi connector A to amplifier connector B accordingly
-matching wires from amplifier connector A to Metra plug accordingly
-matching wires from amplifier connector B to navi connector B accordingly
-split wires from navi connector A to navi connector C
-pickup reverse signal: Splice wire from "A6 GRN/BLK" on the driver side fuse box
-pickup VSS signal: Splice wire from "B2 BLU/WHT" above gauge
-if required, use Cat5 ethernet cable to extend signal wire to avoid interference.
Anger index
4. Placement of the GPS antenna
- cut the ziptie on metal plate and loose 2 screws underneath
- turn the metal plate 180 degree and re-tight back gps mouse
- find 2 coarse thread screws to fix GPS mouse to the duct
Anger index
5. Plug-in
-all the harnessessss and ziptie any loosing wires.
-use 40-HD20 adapter to connect factory antenna to the navi unit
Anger index
6. Restoring audio panel using pdf manual in "1."
Anger index
And you're done!
Enjoy and have fun
Alan 2001 is offline   Reply With Quote Quick reply to this message
Old March 11th, 2009, 10:56 PM   #2
J36 6sp w/ LSD
pigpig000's Avatar
Send a message via MSN to pigpig000 Send a message via Skype™ to pigpig000
Nice~~
pigpig000 is offline   Reply With Quote Quick reply to this message
Old March 11th, 2009, 11:26 PM   #3
3.56thgen's Avatar
what the hell....props dude mad props
3.56thgen is offline   Reply With Quote Quick reply to this message
Old March 11th, 2009, 11:42 PM   #4
4.0L
VietNinjaJ30A1's Avatar
awesome! i've been waiting for this!
Old March 11th, 2009, 11:46 PM   #5
THLA 2009 Bombsquad
Dtownz Thrillah's Avatar
Yes!
I can get a CRV unit for cheap but I dont know if I have that much patience haha
Old March 12th, 2009, 01:17 AM   #6
4.0L
Sell it to me! I can be patient for both of us...I can't find one =[
Old March 12th, 2009, 01:24 AM   #7
✠ 2nd Amendment'r ✠
99cfENVYv6's Avatar
ive never seen a cr-v unit for cheap, scoop it up if you can!
Looks good!
Old March 12th, 2009, 01:33 AM   #8
xXxCLS bOoStEdXxX
slowaccord's Avatar
very nice!
Old March 12th, 2009, 07:50 AM   #9
Euro accord wannabe
aznboi128's Avatar
so much work... yet so clean
aznboi128 is offline   Reply With Quote Quick reply to this message
Old March 12th, 2009, 10:17 AM   #10
THLA 2009 Bombsquad
I can get the unit itself but I think the amplifier is another thread haha
Old March 12th, 2009, 10:36 AM   #11
awww cute stickers
AngusTEx's Avatar
Wow. Just...wow.
AngusTEx is offline   Reply With Quote Quick reply to this message
Old March 12th, 2009, 11:56 AM   #12
Legendaryyaj's Avatar
Send a message via AIM to Legendaryyaj
Daytime pics of fit and finish?
Legendaryyaj is offline   Reply With Quote Quick reply to this message
Old March 12th, 2009, 12:02 PM   #13
方法についてはあなたが私のお尻にキス
Henrys86's Avatar
great DIY, if i had my accord running rit now i'd jump on this idea.
i vote this thread to be
sticky
Henrys86 is offline   Reply With Quote Quick reply to this message
Old March 12th, 2009, 01:35 PM   #14
original member!
Nittanys1's Avatar
thats nicely done!
Old March 12th, 2009, 02:12 PM   #15
4.0L
There was another Accord on here (RHD) that had the CR-V navi. No instructions for a DIY though...but if you search they had posted pictures of the finished install during the daytime. I'm debating whether or not DVD capability is a good trade off for a 100% OEM look or not.
Old March 12th, 2009, 02:23 PM   #16
that pretty sick man. I am lovin it.
Old March 12th, 2009, 02:34 PM   #17
chiefy's Avatar
this is great... good job and nice write up
spool or be schooled!
Old March 12th, 2009, 03:21 PM   #18
THLA 2009 Bombsquad
Im sure that there is a wire out there to hook up your iPod and make it dvd compatible.
If my friends 2003 M3 can do that then I am sure that this unit can do it too Jeff =]
Old March 12th, 2009, 03:28 PM   #19
THLA 2009 Bombsquad
http://www.v6performance.net/forums/...postcount=1885
Old March 12th, 2009, 06:46 PM   #20
Growth Chart Specialist
Shenaniganz08's Avatar
ill buy that CR-V navi !
Old March 14th, 2009, 04:27 PM   #21
Nice retrofit and awesome DIY! Did you have to any slicing up of the dash to make the navi fit?
upschi23000 is offline   Reply With Quote Quick reply to this message
Old March 14th, 2009, 06:15 PM   #22
6th Gen Fanatic
Send a message via AIM to Nismode
Subscribed. If the fit is OEM, I may consider this
Nismode is offline   Reply With Quote Quick reply to this message
Old March 18th, 2009, 01:25 AM   #23
hi. kinda both yes and no ....
navi itself no, no slicing required to fit... just like replacing oem headunit.
but yes only for installing cassette player console for the amplifier.
Old March 18th, 2009, 02:09 AM   #24
4.0L
Alan, in your other thread you labelled a lot of the connectors on the back of the navi but you didn't specify what they were used for, are they just unused?
Old March 18th, 2009, 01:37 PM   #25
┌∩┐(◣_◢)┌∩┐
skatingclaybird's Avatar
Sticky!
Old March 18th, 2009, 10:33 PM   #26
Man that is the sex!
Im with Viet though, is it worth the dvd sacrifice. The screen on the aftermarket units are also bigger though. Dont know how good the Honda Navi is though. Ive heard the TL units are garbage but not sure if that applies to all the Honda cars as well.
Old March 23rd, 2009, 12:33 AM   #27
hi at the end of the day there'd be 3 to 4 connectors left unused.
so far i only know 2 of them which is XM / CD changer and climate control... i really hv no cluess for the rest
Old March 23rd, 2009, 11:10 AM   #28
JV6
So Clean man! seeing these screens makes me sick of my mp3 unit!
JV6 is offline   Reply With Quote Quick reply to this message
Old April 12th, 2009, 08:42 AM   #29
RDuke's Avatar
Great job
RDuke is offline   Reply With Quote Quick reply to this message
Old April 22nd, 2009, 11:45 PM   #30
Team Haidabo
taospec's Avatar
Send a message via MSN to taospec
Nice!!! Now you can do mine!
taospec is offline   Reply With Quote Quick reply to this message
