C.F. Hood problem - Honda Accord Forum : V6 Performance Accord Forums
Old April 14th, 2009, 10:20 PM   #1
C.F. Hood problem
I just bought OEM style CF hood. it fights but it doesnt fit prefect. 1 side go goes up and when i drive it shakes. Any know what to do? would pins press my hood down?
v13tb0i4sho is offline   Reply With Quote Quick reply to this message
Old April 14th, 2009, 10:28 PM   #2
-Maninder
Many CF hoods just fit like that...
Yes, you can try pins, that would more than likely help.
Old April 14th, 2009, 10:28 PM   #3
KT!
icantsleeps's Avatar
Send a message via AIM to icantsleeps
i have a 98 cf hood on my 02, i just took off the shocks
icantsleeps is offline   Reply With Quote Quick reply to this message
Old April 14th, 2009, 10:31 PM   #4
CRV_33's Avatar
thats assuming he has v6 engine.
Old April 15th, 2009, 03:51 PM   #5
SD's Panda
sd2000av6's Avatar
Send a message via AIM to sd2000av6
if one side is lifting you can try adjusting the hood latch on the car to see if its lining up with the latch on the hood if its not perfect it can sometimes make the hood tilt one way when closed. also try adjusting (up or down) the rubber "cushion" on the left and right on the radiator support.
sd2000av6 is offline   Reply With Quote Quick reply to this message
Old May 6th, 2009, 03:32 PM   #6
thx guys. im try hood pins . but that juss ruins the hoood
Old May 6th, 2009, 03:51 PM   #7
b20vem1
CG_TypeR's Avatar
mine use to be like that it was moving up and down. i found out it was the hangar part that attaches to the car. the cf hood latch diameter is too thin. i had to wrap some duck tape to it to make it stop bouncing up and down
CG_TypeR is offline   Reply With Quote Quick reply to this message
Old June 2nd, 2009, 01:04 PM   #8
jaz
Currently Swapping
jaz's Avatar
mine does that on highway as well.. hood pins ftw
jaz is offline   Reply With Quote Quick reply to this message
Old June 13th, 2009, 12:10 AM   #9
San Francisco
nf3d0149ab's Avatar
I have a VIS CF Hood on my 2nd Gen CL-S and it's normal for that shaking after a certain speed.
I would recommend hood latches rather than hood pins.
nf3d0149ab is offline   Reply With Quote Quick reply to this message
