Air/Fuel gauge question - Honda Accord Forum : V6 Performance Accord Forums
Old September 4th, 2009, 08:38 PM   #1
how do i install the air/fuel gauge on my av6? i started looking it up but couldnt find exact ways for my accord.
mackdaddy69 is offline   Reply With Quote Quick reply to this message
Old September 4th, 2009, 08:40 PM   #2
Boosted
1nonlyaccord's Avatar
no point unless its a wideband..if its a normal narrow band your just gonna have flashy lights..
Old September 4th, 2009, 08:42 PM   #3
really? well i found both of them but what is the different. Im sorry im new to all this gauge stuff and how they all work.
Old September 4th, 2009, 08:43 PM   #4
chiefy's Avatar
yea if its not a wideband its useless.
spool or be schooled!
Old September 4th, 2009, 08:48 PM   #5
Boosted
widebands are 200$+ that actually read your AFR..where the others are 40$+ and run off the o2 sensors causing not a single accurate reading.itl just flash from rich to lean constantly back n forth through out your driving.no matter what.
Old September 4th, 2009, 08:50 PM   #6
oh alright i get that. yea i found a glowshift one for $199 so yea ill end up going with that and i dont know if im going to get one or two more im deciding. the other two will be mostly for looks i mean like a volt meter, and maybe an oil pressure one. which i dont know how to install either but that question will be asked in time. Thank you
Old September 4th, 2009, 08:55 PM   #7
Boosted
if anything spend 200$ on the AEM wideband man..seriously. as for the others..glowshift would be fine for volt and oil pressure..i personally run AEM wideband and autometer:boost,water and oil pressure
Old September 4th, 2009, 08:56 PM   #8
alright ill look into that sounds good. thank you!
Old September 4th, 2009, 08:58 PM   #9
Boosted
np..and the glowshift pillar pods fit like crap..ha i have one..so maybe look into the autometer one.
Old September 4th, 2009, 08:59 PM   #10
oh really? ha i was just looking at the glow shift ones alright ill look into the autometer ones. thank you again man
Old September 5th, 2009, 04:24 AM   #11
Mike
SKY99's Avatar
AEM and Autometer are probably a better choice
Remember to wire it up before your cat, it's pointless otherwise.
SKY99 is offline   Reply With Quote Quick reply to this message
Old September 5th, 2009, 07:26 AM   #12
Boosted
Oh ya.your gonna have to get another 02 bung welded in your header..for the new wideband 02 sensor...
Old September 5th, 2009, 12:23 PM   #13
4.0L
VietNinjaJ30A1's Avatar
I think there's a thread where someone talked about how to install an oil pressure gauge.
Old September 9th, 2009, 10:02 AM   #14
alright thanks that sounds good i think ill do it.
Old September 9th, 2009, 02:32 PM   #15
Daniel
toocooldg's Avatar
is there no other way... this seems like a lot of work
j32 6spd beast
toocooldg is offline   Reply With Quote Quick reply to this message
Old September 9th, 2009, 05:10 PM   #16
Boosted
No,AFR gauges are mainly for turbo or SC people that are actually adding air and fuel to an NA engine..other than that this is just for show and to say i have an AFR gauge..
and with that said,its usually welded into the turbos downpipe when its made anyways...so yes to add it to a stock car with an intake and headers is pointless and alot of work.
untuned turbo 217.01whp,238.46wtq
RETUNED @11psi- 281.94whp/280.56wtq
Official Slammed Club Member #51-Stage 3
