urgen help with 01 accord power window fuse keep on blowing - Honda Accord Forum : V6 Performance Accord Forums
Old November 29th, 2009, 09:14 AM   #1
so i just bought this 01 accord coupe and the right window power abviously didn't work, so i check the fuse and it blew, then i replaced it and it blew right away as soon as i replaced it. what the heck is wrong with it? this car used to have sound system as i can see couple wires in the trunk....please help out asap. thanks
vtecownedyou is offline   Reply With Quote Quick reply to this message
Old November 29th, 2009, 05:48 PM   #2
15 viewers and still no help.
Old November 29th, 2009, 05:58 PM   #3
M90SC Boosting 13PSI
NVA-AV6's Avatar
If it blows as soon as you put the fuse in you have a short somewhere in the system before the switch and you need to trace it out, if it blows as soon as you press the switch then it can be the wiring from the switch to the motor, or the motor is bad. Try disconnecting the motor, if it does not blow, then it is probably a bad motor.
Old November 30th, 2009, 12:12 AM   #4
Growth Chart Specialist
Shenaniganz08's Avatar
could be a lot of things ( shorts are pretty hard to diagnose)
I would take everything apart and look for loose wires. It could be you have a frayed wire/open wire that is shorting out ( try wrapping any exposed wires in elecctical tape)
Old December 1st, 2009, 12:22 PM   #5
thanks for the helps guys, i tried all sort of things but couldn't figure out the problem, just took it to the shop for further diagnose, will update later
Old December 2nd, 2009, 03:15 PM   #6
I had a similar issue with the fuses blowing but with the motor on my power mirrors... seems the motor was bad and was stressed everytime it moved so drew more amps than it should .. pop went the fuse
agito88 is offline   Reply With Quote Quick reply to this message
Old December 3rd, 2009, 09:13 AM   #7
brought it to a bad shop, they replaced multiplexer and switch and charged 380 bucks. took them 3 freaking days and could find out where the short is so they finaly replaced those parts and messup my all my interior light and factory alarm sec.
Old December 3rd, 2009, 01:46 PM   #8
Thats not bad.
I had a 'short' somewhat that wasnt blowing fuses, but caused tons of problems.
Replaced the ECU, both multiplexors, fuseboxes, a few relays, and other misc... $1300 and out the door in just under a month. They never told me what was wrong... Since they didnt know. These guys arent usually very intelligent. And this was at a Honda Dealer.
Was the problem resolved?
Old December 4th, 2009, 06:35 AM   #9
$380 is pretty good for electronic diagnostic and fix .. well assuming they fixed it
Old December 4th, 2009, 08:23 AM   #10
after i did lot of reseach online and tried to figure out the problems, i was going to replace that multiplexer but didn't want to. so i decided to bring it to this shop and assumed that they have more knowledges about electric than i do to find out where the shorts are, but turn out not what i thought.
yes the problem fixed, but they messed up my factory alarm sec sytem and they didn't know how to reset it so i had to reset it myself by researched online haha.;
Old December 4th, 2009, 11:07 AM   #11
Yea, I wanted to fix my car myself but I was busy with school and my dad forced me to take it to the dealer after it sat for 2-3 days...
I basically told them what to do, since they had no clue. They replaced parts that didnt need replacing and charged me for them of course...
And my running lights went out in the process and they never address that issue, I had to myself.
Electrical issues arent allways a easy thing to fix... Most 'mechanics' want to see a tire fall off, then they know what to do to fix it. Electrical isnt always as clear....
Old July 3rd, 2010, 11:18 AM   #12
Banned
Internal Medicine Garland Gary Green
Pills Stamped Bt 72 - news <a href=bbg4tucson com/>phentermine adipex 37 5 mg</a> Adipex is an appetite suppressant that in combination with a healthy diet and exercise will successfully help you to lose weight bbg4tucson com/]buy adipex 37 5 online If you want to lose weight you really need to put yourself on a healthy diet and efficient exercise program bbg4tucson com/ - adipex phentermine 37 5 mg Most of the people that are over weight are over weight for a reason
BUrgerelak is offline   Reply With Quote Quick reply to this message
