Need your LED Conversion done? version 2 - Honda Accord Forum : V6 Performance Accord Forums
Old December 12th, 2009, 06:17 PM   #1
New Member
aznfunkyflip's Avatar
I know I created a thread like this 5 years ago, but I just thought I'd created a new and updated one.
If you need to convert your interior lights to LED, I could do it for a good price. I've done it many times to members here and i'm sure a lot of people could vouch for my work.
You dont have to be in So. Cal to get this deal 'coz you can also send the item you need to be done and i'll send it back to you with the LED installed and ready to go and all you gotta do is put it back in your car. I usually finish the job the same day I recieve the package and ship it back the same day or the next day.
Things that you can usually convert are:
- clock
- climate controls
- sunroof control
- tcs and cruise controls
- oem radio
- fog light control
- Odometer
- Gauges (RPM, MPH, Gas, and Temp)
- Gauge Turn Signals
can also do a custom LEDs on the air vents
here's a pic of my old set-up.
new set-up
Old December 12th, 2009, 06:42 PM   #2
V6 6SPD
allgonoshow's Avatar
God that looks good.
2002 Fully Loaded V6 6MT
allgonoshow is offline   Reply With Quote Quick reply to this message
Old December 12th, 2009, 06:57 PM   #3
same avatar since 03'
kEyChAiN's Avatar
Send a message via AIM to kEyChAiN
Roger does great work! I can vouch for him. I'll PM you soon Roger .
kEyChAiN is offline   Reply With Quote Quick reply to this message
Old December 14th, 2009, 11:40 AM   #4
4.0L
VietNinjaJ30A1's Avatar
How much?
Old December 14th, 2009, 12:15 PM   #5
Arlorn87's Avatar
This may be a stupid newbie question but... can the brightness of your LED's be controlled with the dimmer?
Arlorn87 is offline   Reply With Quote Quick reply to this message
Old December 14th, 2009, 12:35 PM   #6
New Member
Originally Posted by VietNinjaJ30A1 View Post
How much?
PM me with what you want and i'll give you a price.
yes, but ppl always want their LEDs brighter.
Old January 25th, 2010, 09:40 PM   #7
TD = The Destroyer
oltorftd's Avatar
i did a led conversion but the clock is really dim. i can barely read it. where do you get the LED for the clock that doesn't suck? also, for the odometer. mine's bright enough to read but the edges are pretty dim.
oltorftd is offline   Reply With Quote Quick reply to this message
Old January 25th, 2010, 09:44 PM   #8
New Member
did you removed the filter behind the clock?
Old January 25th, 2010, 09:47 PM   #9
TD = The Destroyer
oltorftd's Avatar
no i didn't. how do you do that? is there a filter behind the odometer too?
Old January 25th, 2010, 10:00 PM   #10
New Member
thats the reason why your clock is dim.
as for the odometer, it doesn't have any filter, but the reason why the center is brighter is because maybe your LED isn't shaved. i shave my LED so the light output is wider.
Old January 25th, 2010, 10:03 PM   #11
TD = The Destroyer
oltorftd's Avatar
ok, i just removed kind of a blue thing with a black frame on one side. it's marginally brighter, but i think i need to aim the led. i'll try that.
Old January 25th, 2010, 10:07 PM   #12
New Member
Old January 25th, 2010, 10:23 PM   #13
TD = The Destroyer
oltorftd's Avatar
well what do you know. it worked. thanks dood.
Old January 27th, 2010, 11:53 PM   #14
holy ****
jspic531 is offline   Reply With Quote Quick reply to this message
Old February 21st, 2010, 07:00 PM   #15
hotfinwax's Avatar
Send a message via AIM to hotfinwax
i am sending you a pm as we speak :P
hotfinwax is offline   Reply With Quote Quick reply to this message
Old February 21st, 2010, 08:43 PM   #16
once it gets warmer and i won't need my heat you got some business ahah
DaSmittyman is offline   Reply With Quote Quick reply to this message
Old February 23rd, 2010, 11:56 AM   #17
hotfinwax's Avatar
Hey I sent u a pm requesting a quote so u think you can do it?
Old February 25th, 2010, 02:31 AM   #18
New Member
sorry for the late response. havent been on the site for a long time.
all PMs have been replied.
Old February 25th, 2010, 02:43 AM   #19
The End.
IcyAccord's Avatar
flickr&mpt=[CACHEBUSTER]">
Old February 28th, 2010, 11:19 PM   #20
┌∩┐(◣_◢)┌∩┐
skatingclaybird's Avatar
i still want
Old March 2nd, 2010, 01:20 PM   #21
Craziest Viet Mofo You'll Know
vsop accord v6's Avatar
Send a message via AIM to vsop accord v6
I have a question about the LED conversation. I recently did my conversation a couple of weeks to a month ago and my LEDs would flicker and then stay on. Sometimes it would just flicker and then just stay off. It only happens to some of the LED where the other ones would just work like they need to. Could it be a weak solder or a bad resistor? Any ideas?
vsop accord v6 is offline   Reply With Quote Quick reply to this message
Old March 2nd, 2010, 01:29 PM   #22
New Member
your LED is about to die.
Old March 2nd, 2010, 02:59 PM   #23
Even though its brand new?
Old March 2nd, 2010, 03:43 PM   #24
New Member
LEDs are mass produced in large qty and doesn't get check every single one. you will have a defective every once in a while.
that's why parts that goes to aerospace gets stress check before it goes up.
Old March 3rd, 2010, 09:01 AM   #25
OG helping OG. lol thanks man!
Old March 3rd, 2010, 02:32 PM   #26
smashVTECftw's Avatar
nice set up, i like the blue.
smashVTECftw is offline   Reply With Quote Quick reply to this message
Old March 15th, 2010, 03:06 AM   #27
6th. gen Stunna
Hondamugen's Avatar
Send a message via AIM to Hondamugen
nice job on the interior leds, but what about exterior leds? like tail lights?
Hondamugen is offline   Reply With Quote Quick reply to this message
Old March 15th, 2010, 09:34 PM   #28
New Member
not offering exterior LEDs at this time. I've only sold 1 pair of tail light to a member here.
Price tag for the tail lights scare people away. lol
Old March 24th, 2010, 10:48 AM   #29
hotfinwax's Avatar
hey roger thanks again for the conversion! you did a wonderful job and im so mad i forgot my gauges lols.. having a hard time finding someone who knows how to do it correctly haha. but definetly great job!
Old March 24th, 2010, 11:07 AM   #30
New Member
glad you like it Joey. if you cant find someone who'll nstall your gauges right, just let me know
