Help on new car audio - Honda Accord Forum : V6 Performance Accord Forums
Old January 28th, 2010, 12:07 PM   #1
AccordWhite00's Avatar
I have a 2000 accord coupe.
I want to change all my speakers and replace them with Kicker or something with and amp.
Any recommendation? thanks!
AccordWhite00 is offline   Reply With Quote Quick reply to this message
Old January 28th, 2010, 12:20 PM   #2
Brad
bdeitemeyer's Avatar
Kicker speakers aren't special at all. What's your budget?
Old January 28th, 2010, 02:52 PM   #3
:::::::Gettin' By:::::::
V6nighthawk00's Avatar
I like Pioneer and JBL speakers. Currently I have all pioneer speakers (6.5 component set in the front, 6x9 in the back) but I've had JBL's in my old car. The best thing to do is take your own music, listen to different speakers and pick the ones you like. Then go buy them online...it's cheaper.
Power is nothing without control... ~R.I.P.~
V6nighthawk00 is offline   Reply With Quote Quick reply to this message
Old January 28th, 2010, 03:39 PM   #4
Super IcyAccord
changaroo's Avatar
alpineee is good too
along with infinity, mb, jl, and eclipse.
another underrated often unheard brand is image dynamics, really good quality ish.
btw, if you go 6x9's in the rear, you have to get shallow mount speakers or it will rub on the trunk spring everytime you open / close it.
you could just run a 6x9 -> 6.5 adapter and use 6.5's much easier that way.
Old January 28th, 2010, 11:10 PM   #5
Hmmm thanks for the ideas.
I wanna get each set at a time like rear, then front, then tweeters, and maybe a amp to power it all...
500 is the range right now, but it'll end up more.
I listen to everything haha, I dunno the watts, ohm, 4 way Im lost when it comes to that
Old January 29th, 2010, 12:15 AM   #6
1bLwN_AcCoRd's Avatar
Send a message via AIM to 1bLwN_AcCoRd
if you love music and like to really experience the music i'd recommend some quality brands like: hertz, morel, rainbow, seas..
1bLwN_AcCoRd is offline   Reply With Quote Quick reply to this message
Old January 29th, 2010, 07:58 AM   #7
07' V6 Auto Sedan
dnlgao's Avatar
Send a message via AIM to dnlgao Send a message via MSN to dnlgao
dude.. some of the best speakers for the money would be infinity kappa perfects.. everyone has a friend who works at best buy. so find someone who can grab you a pair of the 6.5 comps for about 60-70 i think and the 6x9's for about 120 of so, on discount. then use the rest of the money to buy a 400 watt FOUR channel amp. make sure its FOUR channel. and then youre good to go.
dnlgao is offline   Reply With Quote Quick reply to this message
Old January 29th, 2010, 02:21 PM   #8
If I get a 400w amp would it work with a 300w speaker?
Old February 1st, 2010, 01:36 PM   #9
if you're getting a 400 watt 4 channel amp that rating is probably at a 2 ohm load. sense most component speakers are 4ohm you wont be getting that much power to them. more than likely an amp like that will be putting out around 25watt at 4ohm per channel which is underpowering the speaker.
SHORT ANSWER: yes, but the speaker will be underpowered
Amps have power ratings at 2 ohm and 4 ohm (level of resistance). Speakers come as 2 ohm or 4 ohm (typically 4) and that will determine how much power the amp is putting out. Also the power ratings for the amp should be rms not max wattage while that 300 watt speaker rating is at max wattage.
Crutchfield is a good site to find the rms wattage of speakers (typically a range). When you pick out the speakers you want, look at the rms wattage (amount of power they can handle continuously) and buy an amp that can put out that much power or close to it. you can buy an even more powerful amp than that just make sure it doesnt put out more power than the max wattage rating of the speakers
and like said before, if you're wanting to do new front and rear speakers make sure you buy a FOUR channel amp. i've taken out my rear speakers and will eventually be buying a 2 channel amp to power my 2 front speakers....hope this helps
i found THIS site very useful when i was learning about stereo systems
kn0x47 is offline   Reply With Quote Quick reply to this message
Old February 3rd, 2010, 01:02 PM   #10
What everyone said before is good advice. I prefer Infinity as a speaker brand, most of that is personal preference as long as you get a reputable brand. The only thing I want to add is that I got the feeling from your previous post that you were thinking about getting them at different times. I would suggest that you wait to put them in(if you are doing it yourself) until you have everything. I have installed many car stereos in my cars and friends cars and its always easier to do the entire thing first instead of going back and adding an amp later. It saves time on taking panels apart and you can do all of your wiring at one time.
ben2080 is offline   Reply With Quote Quick reply to this message
Old February 11th, 2010, 11:27 AM   #11
go with JL speakers
godfatherpart3 is offline   Reply With Quote Quick reply to this message
Old February 11th, 2010, 11:31 AM   #12
I personally hate the sound of infinity speakers. The tweeters are waaaaaay to over bearing. If ur lookin for some sound info, go to caraudio.com or diymobileaudio.com. Lots of info. Image dynamics isnt underrated either, its just expesive lol.
BabyHuey is offline   Reply With Quote Quick reply to this message
Old February 20th, 2010, 02:35 PM   #13
true
jfigueroa49 is offline   Reply With Quote Quick reply to this message
Old February 20th, 2010, 02:40 PM   #14
original member!
Nittanys1's Avatar
Originally Posted by jfigueroa49 View Post
true
true what?!? dude you are continuing to go around and post one word responses....STOP IT!
Old February 21st, 2010, 08:01 PM   #15
Accord_J30a's Avatar
Send a message via AIM to Accord_J30a Send a message via Yahoo to Accord_J30a
Lol seems like you been keeping track of this guy
Accord_J30a is offline   Reply With Quote Quick reply to this message
Old February 21st, 2010, 09:40 PM   #16
original member!
Nittanys1's Avatar
^well he was post whoring when I was browsing the boards and lighting up email box with his useless posts....
Old February 22nd, 2010, 06:53 AM   #17
^^Yea I notice too.
Old March 3rd, 2010, 08:23 AM   #18
What 6X9's fit into the 6th gens rear deck?
Old March 3rd, 2010, 08:28 AM   #19
original member!
Nittanys1's Avatar
prety much any style. check out www.crutchfield.com and put in your cars model there. they will tell you all that will fit. then you could go to ebay or amazon to buy the speakers for less...
Old March 3rd, 2010, 09:40 AM   #20
I went there and called them they said I need to get a 6.5 and a 6x9 adapter plate -____-
Old March 3rd, 2010, 09:45 AM   #21
original member!
Nittanys1's Avatar
odd...i didnt and I have had three different 6x9s the only problem i ran into with one of them was the grill cover not wanting to go back on. the simple fix for that was trimming the little ring off that is on the underside of the grill cover.
Old March 3rd, 2010, 10:00 AM   #22
yeah, go to that site and put in 2000 accord coupe and they only show 6.5 and smaller for my car
Old March 5th, 2010, 12:33 PM   #23
I'm planning on MBQuart 6.5 components upfront and MBQuart 6x9's in the rear shelf. And then one JL 10" dual VC firing right through the armrest in the backseat.
Not sure on the HU though. I would like 2 din with HD and bluetooth capabilities.
Kville02Accord is offline   Reply With Quote Quick reply to this message
Old March 5th, 2010, 12:53 PM   #24
jsiriusvtec
Guest
Posts: n/a
A nice 15" Solo-Baric in the trunk will hit so hard it's difficult to drive.
Old March 5th, 2010, 04:21 PM   #25
blackA-cord's Avatar
to Kville02Accord- i got a nice double din sized pioneer, not dvd tho just cd player ipod adapter included and it has bluetooth. i know kenwood and one other brand for sure has the nice 2din non dvd screen units you can check em out on crutchfield then ebay one for less. i knew i wanted the 2 din size for the clean look but had no need for a dvd player so check em out there priced good too not too expensive
blackA-cord is offline   Reply With Quote Quick reply to this message
Old March 5th, 2010, 08:35 PM   #26
Soo I got
Infinity Kappa's 2 way components in the front
Infinity Kappa's 2 way 6X9 in the rear deck (Gonna make it fit haha)
and a JVC KD-A605 head unit which is pretty baddass
Old March 5th, 2010, 08:37 PM   #27
original member!
Nittanys1's Avatar
nice job on the Kappas! I loved my 2 ways in the doors back in the day! OI dont think you'll have a problem fitting the 6x9s
ont forget to take installed pics!!!
Old March 5th, 2010, 08:42 PM   #28
Lol I will just for you haha
I got a question is it hard to get the rear speakers out? Cuz it seems like its at a hard angle
Old March 5th, 2010, 08:48 PM   #29
original member!
Nittanys1's Avatar
naw, not with a small ratchet set. just make sure to take your time and if you have tint be careful of hitting that with your tools. the hardest part i remember was getting the grill cover off there are a few screws holding it on from within the trunk (underside) and the pop rivets (those things are a PITFA!!!
Old March 5th, 2010, 10:17 PM   #30
lol i took the grill off before, just a PITA to get in the trunk and turning the screws haha
Are the speakers mounted with Philips screws or bolts?
