Swap questions - Honda Accord Forum : V6 Performance Accord Forums
Old February 10th, 2011, 07:38 AM   #1
Don't warp it -Torque it
Str8racn's Avatar
Swap questions
I have lights going out on my instrument cluster, clock and a/c control. I have seen some have swapped these parts out with 6th Gen coupes and want to find out if there are mods needed to make the cluster work or if it is "plug and play". I have searched the forums with ZERO results so posting this question.
Thanks in advance.
If you talk the talk, but don't walk the walk. Well....That makes you a phony.
Str8racn is offline   Reply With Quote Quick reply to this message
Old February 10th, 2011, 11:12 AM   #2
so your askin if you can swap instrument cluster only ?
overboostin is offline   Reply With Quote Quick reply to this message
Old February 10th, 2011, 11:59 AM   #3
Str8racn's Avatar
What if any mods are needed basically. Would I need the bezel out of a coupe, are the plugs the same on the backside.
If it is too much of a hassle, I may just pull it out along with the rest of the bulbs on the other components and change the color of the bulbs. I like the Coupe cluster much better than the sedan design.
Old February 10th, 2011, 01:17 PM   #4
Str8racn's Avatar
Cool
Found a link to a company that sells kits for our cars in different colors. Think I am going that route. Let me know if anyone reading this post would like the link.
Old February 10th, 2011, 06:23 PM   #5
SeanUCF's Avatar
Yes, please share the link. Most likely someone here can give you some input on the product since there isn't a whole lot out there.
SeanUCF is offline   Reply With Quote Quick reply to this message
Old February 10th, 2011, 06:41 PM   #6
Str8racn's Avatar
It is LED Automotive
Interior LED conversions that replace or upgrade stock incandescent bulbs
