All RED Taillights - Honda Accord Forum : V6 Performance Accord Forums
Old July 10th, 2011, 12:45 PM   #1
honda_dude's Avatar
All RED Taillights
I spray paint my reverse and signal turn light with RED Stained glass spray paint from Krylon. it was $9.99 a can a Michael's but had a 40% off coupon . I painted the first coat yesterday. Wet sanded it just now with 1000 grit then lightly sprayed a second coat. Im waiting for it to dry so i can paint clear coat on it.
Should I wet sand (what grit, 1000 ok?) b4 putting clear coat on it?? And What clear coat brand/type should I use? AND how should I spray the clear coat on?? THICK layers? Multiple thin layers? Am i missing any steps before i should spray clear coat on? Thanks in advance guys.
it looks much lighter in person..its dark cause it was takin from my iphone.
honda_dude is offline   Reply With Quote Quick reply to this message
Old August 1st, 2011, 05:02 PM   #2
Ob3y5teeze
SixGenAccordLx's Avatar
nicee i want to paint mine also. any pictures of the results?
SixGenAccordLx is offline   Reply With Quote Quick reply to this message
Old August 1st, 2011, 06:02 PM   #3
Always spray in thin multiple coats can't go wrong and I wouldn't wet sand before hand just get it with the clear while the paint is still a little tacky and you'll be golden
Rushzer0 is offline   Reply With Quote Quick reply to this message
Old August 13th, 2011, 04:40 AM   #4
MARTIN
TRUV6's Avatar
huh? Rushzer0 -I don't think you should sand anything while it's still tacky, even if it is just a little tacky. I've done that accidentally once and it turned out horrible.
Once you get the clear on I would just buff it out and polish it. You don't want to scuff up a surface that has light shining through.
TRUV6 is offline   Reply With Quote Quick reply to this message
Old August 13th, 2011, 09:04 AM   #5
I never said sand while it was tacky lol that's just silly ahaha I said don't sand at all, hit it with the clear when the paint is still a lil tacky so it has that to adhere to, that more clear? LoL!
Old August 14th, 2011, 01:07 PM   #6
MARTIN
TRUV6's Avatar
Yeah, I must have mis-understood
Old August 30th, 2011, 02:57 PM   #7
Looking forward to the after pictures! Just spent the weekend taking out the amber inserts on the turn signals! (Pretty easy if you haven't done it and want to)
h0p3l355dork is offline   Reply With Quote Quick reply to this message
Old September 6th, 2011, 05:04 PM   #8
can we see a picture of after?
indiankid is offline   Reply With Quote Quick reply to this message
Old September 6th, 2011, 07:23 PM   #9
AccordWhite00's Avatar
its going to fade.
AccordWhite00 is offline   Reply With Quote Quick reply to this message
Old September 7th, 2011, 07:04 PM   #10
^^^ what would be a better way to get all red tails?
Old September 7th, 2011, 09:54 PM   #11
clear red vinyl, it may fade, even if it does fade it will fade evenly.
I sprayed my tails once, even with clear it faded.
Old September 8th, 2011, 07:55 AM   #12
oh alright thanks you
Old September 11th, 2011, 08:45 PM   #13
4.0L
VietNinjaJ30A1's Avatar
I used transparent red Oracal film to tint my turn signals red. It was pretty easy to apply. I used a heat gun, heated, stretched, adhered and then used a razor blade around the edges to cut off excess. It lasted for years.
