stock tire size question - Honda Accord Forum : V6 Performance Accord Forums
Old January 27th, 2004, 02:38 PM   #1
XmEnB!sHoP
SAV602's Avatar
whats the largest tire size i can put on a stock rim...ona 02 av6 ex
what brands would you guys recommend. I live in the bay area so no snow.
thanks
2002 AV6|19" VOLK GT-7's|Tein Coilovers|13" 4 Piston Wilwood|Comptech Sways|MB Quart|AEM CAI|
SAV602 is offline   Reply With Quote Quick reply to this message
Old February 6th, 2004, 11:18 AM   #2
XmEnB!sHoP
SAV602's Avatar
bump
Old February 10th, 2004, 03:55 PM   #3
XmEnB!sHoP
SAV602's Avatar
bump
Old February 10th, 2004, 05:27 PM   #4
have you tried searching at all?
AF_BRYAN is offline   Reply With Quote Quick reply to this message
Old February 10th, 2004, 09:54 PM   #5
You might be able to go with 215/70/15(6) or
225/70/15(6)
what is the diameter of your wheel? 15"? 16"?
On my mitsubishi Mirage I went from 145/80/13 to 175/70/13.
Hope this helps give you an idea.
andreivtec is offline   Reply With Quote Quick reply to this message
Old February 11th, 2004, 06:35 AM   #6
HONDA_99's Avatar
225/70/15(6)
that is just right tire size.
If you want to rock climbing in you accord.
215/70/15 one inch higher and 225/70/15 two inches higher then stock tire (205/60/16)
225/55/16 is much closer to stock tire height, but its recommended to be fitted on 7" wide rim, however it was designed for rims with 6"-8" width.
215/55/16 is more friendly for 6.5" wide rims, but they bit smaller then stock one.
Old February 18th, 2004, 05:38 PM   #7
#1 Stunna
hondafan's Avatar
Send a message via AIM to hondafan
go with 215/55/16
hondafan is offline   Reply With Quote Quick reply to this message
Old March 15th, 2004, 03:46 PM   #8
XmEnB!sHoP
SAV602's Avatar
Thanks guys i got some 205/55/16... z rated tires from Pep Boys they were on clearance and my friends gave me a couple extra discounts...It's amazing how good my handling is now...best part ive gotten in a long time
Old March 15th, 2004, 05:42 PM   #9
#1 Stunna
hondafan's Avatar
You went too small. Your original diameter was 25.7 inch, now it's only 24.9. Your speedo is now too fast, so when you are going 60mph, you are actually only going 58.1mph. With the smaller diameter, you will also now have a larger wheel/fender gap (although not by a whole lot). Use this tire size calculator before purchasing your next set of tires:
http://www.miata.net/garage/tirecalc.html
It will help you determine what size you need...which is 215/55/16.
Old March 15th, 2004, 07:15 PM   #10
XmEnB!sHoP
SAV602's Avatar
stock was actually 195/60/16 so its not that bad either way.
Old March 16th, 2004, 02:25 AM   #11
#1 Stunna
hondafan's Avatar
If you have an 02 EX-V6, how is your stock 195/60/16? Stock tire size on the OEM 16s is 205/60/16...unless you have the LX or maybe you bought it used and the previous owner put the wrong size tires on.
Old March 16th, 2004, 11:46 AM   #12
XmEnB!sHoP
SAV602's Avatar
nope bought the car new w/195's those were the original tires also.
Old March 16th, 2004, 11:57 AM   #13
#1 Stunna
hondafan's Avatar
You got jipped by the dealer. Take a look at your manual. You will see that the stock tire size for the EX-V6 coupe is 205/60/16. What tires did they give you? It should be Michelin Energy MXV4 Plus.
Old March 16th, 2004, 01:43 PM   #14
XmEnB!sHoP
SAV602's Avatar
i remember they were michelin mxv's not sure what else...i just called my friend at pep boys to confirm my tire size (he looked at the tires not the computer) and they were 195's...
I still need to check my manual...i'm suprised i never noticed the diff between my manual and the actual tire size...is this common practice for dealers to change tires on you seems weird...i'll check manual at break to make sure...if your right the dealer will be getting an ear full
::edit:: its a coupe by the way i'm wondering if that makes a diff
Old March 16th, 2004, 03:22 PM   #15
#1 Stunna
hondafan's Avatar
Yeah, the coupe comes with 205/60/16s while the sedans come with 205/65/15s. I don't think dealers do this normally. I don't know. At least now you have a set you like. Next time, though, try 215/55/16. That's what I have and I have the coupe 16s on my sedan. The wider tire makes it handle a little better.
Old March 16th, 2004, 04:26 PM   #16
XmEnB!sHoP
SAV602's Avatar
I've returned used tires before ill double check if they have the 215's, maybe i can echange 'em.
Old March 16th, 2004, 04:40 PM   #17
XmEnB!sHoP
SAV602's Avatar
ok so now i have a problem...i checked the manual and just like you said hondafan the stock tire size is 205/60/16 for my car. I'm going to Pep boys today to check with my own eyes what my tire size was on the car just to be 100% sure (even though i am already). My tires were always very poor performers. Corners would cause louder than average "chirping" etc. If Honda duped me they will be paying for my new tires. I wonder what there excuse is going to be lol
Old March 17th, 2004, 04:45 AM   #18
#1 Stunna
hondafan's Avatar
Keep us posted. I want to hear what they say. I bet they won't believe you and say that since you already changed tires, they can't do anything about it and that you don't have any proof.
Old March 17th, 2004, 04:46 AM   #19
#1 Stunna
hondafan's Avatar
Oh, and check if they gave you H or V rated tires. You were supposed to get the V rated tires on a V6. I bet they gave you the H rated tires instead since they gave you a 195/60 series tire.
Old March 17th, 2004, 01:35 PM   #20
XmEnB!sHoP
SAV602's Avatar
I left my friend a message to keep the tires i wasnt able to go yesterday...im going there right after work today though...
I'll let you know what they say...right on for all the info man
Old March 18th, 2004, 12:59 PM   #21
XmEnB!sHoP
SAV602's Avatar
bad news...they got rid of the tires...i have two people other than my friend that can confirm that the tires were 195's at pep boys so i'll call honda and see what they say...hopefully pep boys will vouch for me...
Old March 18th, 2004, 05:53 PM   #22
#1 Stunna
hondafan's Avatar
That's too bad man. They probably won't believe you cause there's no real way you can prove that the tires were stock. It's worth a try, though. Maybe you can get a free service out of it.
Old April 1st, 2004, 09:28 AM   #23
XmEnB!sHoP
SAV602's Avatar
I can really feel the difference in my car in re: to rpm's and gas mileage. I'm going to buy the correct tires (215/55/16) and sell the wrong ones. Pep boys has some Futura VR's for 346.32 which is the price out the door. I'll probably get those after i do a little research on 'em. The tread pattern looks less aggressive, but at this point screw it.
I'm not going to persue anything with honda i asked my friend about it and he said they do that sometimes. If i only had those damn stock tires oh well...
hondafan any opinion on brands
Old April 2nd, 2004, 08:21 AM   #24
#1 Stunna
hondafan's Avatar
Research on www.tirerack.com. Kumho is the best bang for the buck. It's all a matter of personal preference and how much you want to spend.
Old April 2nd, 2004, 11:49 AM   #25
XmEnB!sHoP
SAV602's Avatar
right on will do
