Carbon Fiber Roof Overlay Project - Honda Accord Forum : V6 Performance Accord Forums
Old January 29th, 2012, 03:01 PM   #1
Vimal (vee-mall)
KnightRyder's Avatar
let the madness begin.... again.
step one, windshields removed. going to be a busy week long process.
Old January 29th, 2012, 03:02 PM   #2
Vimal (vee-mall)
degreased the roof and started masking off.
i'll start sanding tonight and get it all prepped for tomorrow.
goal is to get the glass put back in by Saturday 2/4/12. If it rains at all then that could delay me because i cant work in humid conidtions, the epoxy would dry way too fast. as it is i have 25 minutes to work with each layer of epoxy. if it gets too hot or too humid, that time goes down very fast.
Old January 29th, 2012, 03:04 PM   #3
Vimal (vee-mall)
anyways, the initial sanding is done, S*** took forever even with an air powered grinder. had to get through clear coat, paint, primer and sealer. im going back tonight to do the detail sanding by hand, like on all the edges and stuff.
car is going to need another major detailing inside out all the metal shavings and paint dust is EVERYWHERE. i covered all the windows too but it still got all over the place.
Old January 29th, 2012, 06:05 PM   #4
MoneyPit's Avatar
I would've sanded what I could on the roof with the front/rear glass still in.
Did you lay down a few practice pieces to make sure the resin color/weave wouldn't contrast with your hood/trunk?
This is going to be badass when complete!
MoneyPit is offline   Reply With Quote Quick reply to this message
Old January 29th, 2012, 08:00 PM   #5
xXxCLS bOoStEdXxX
slowaccord's Avatar
you are too damn handy!
Old January 29th, 2012, 09:05 PM   #6
Vimal (vee-mall)
yea i realize i should have started sanding before i pulled the glass, lol. o well.
i did do a couple practice pieces and it looks pretty good. not 100% identical but very very close. im eventually going to have all the CF LIGHTLY sprayed with NHBP anyways so that will for sure even things out.
Old January 29th, 2012, 09:11 PM   #7
Destroyer of Tires
Doctor_X's Avatar
Can't wait to see how this turns out!
Old January 29th, 2012, 10:32 PM   #8
James
jconnway's Avatar
damn legit! I just did CF vinyl on mine... can't wait to see yours
Old January 30th, 2012, 06:21 AM   #9
Boosted!
ComptechV6's Avatar
wow, im very curious how this turns out.
Old January 30th, 2012, 06:53 AM   #10
Boosted!
ComptechV6's Avatar
where did you get the material to do this?
Old January 30th, 2012, 01:41 PM   #11
Brad
bdeitemeyer's Avatar
Looking good so far Vimal, and I agree about sanding while the glass was still in. Oh well, live and learn.
Old January 30th, 2012, 07:58 PM   #12
Vimal (vee-mall)
best prices i've been able to find are from here... for both the weave and epoxy.
Fiberglass Supply - Carbon Fiber Fabrics, Kevlar Fabrics, Carbon Kevlar Hybrids, Unidirectional Carbon Fiber
item # C53-6285
Old January 30th, 2012, 08:09 PM   #13
Brad
PMed you after hearing back from the shop. Hope it helps bro.
Old January 30th, 2012, 08:21 PM   #14
Boosted!
ComptechV6's Avatar
Wow thankyou!
Old January 30th, 2012, 08:26 PM   #15
v6indodarknight's Avatar
wow... this guy have too much time on his hand...!!!!
hahahha,
nice, can't wait to see final pix,
u never cease to amaze us!!!
&mpt=[CACHEBUSTER]">
click on picture to see my profile
"Not slammed anymore"
v6indodarknight is offline   Reply With Quote Quick reply to this message
Old January 31st, 2012, 02:23 AM   #16
Coldspeed
Metaender's Avatar
Very nice man, this project looks like it'll be a good one. Definitely in for your updates. Car's looking great.
Metaender is offline   Reply With Quote Quick reply to this message
Old February 1st, 2012, 09:42 PM   #17
Vimal (vee-mall)
man, its been what... 4-5 days and the roof was already beginning to rust (while parked inside the garage at all times) just from the moisture in the air. came down to look at my roof this morning to see it looking brown. so i had to go buy a rust removing solution from home depot, cleaned off all the rust, and sprayed the roof with SEM Black Self Etching Primer/Sealer. Im going to use an alternative method to lay the CF down that was brought to my attention by Brad. had i known of that method before, i wouldnt have had to sand my roof down to metal in the first place, since it was already black. o'well.
anyways, i didnt get any pics of the rusted roof but here's a couple of me masking up the whole car and covering it, and the roof after it was painted black again. going to let the paint cure overnight and begin the laying the CF down tomorrow. tomorrow will be an exciting day
Old February 1st, 2012, 11:05 PM   #18
Brad
So the plan B test piece worked out better? If so, glad to hear it (and sorry that you sanded down your roof beforehand).
Old February 1st, 2012, 11:15 PM   #19
Vimal (vee-mall)
i was honestly busy all day training for a new job and then i came home to fix the rust issue so i didnt have a chance to do a test piece. but to tell you the truth, i probably wont do one, it cant be any worse than what i was going to initially do anyways. im probaly going to do the plan B method anyways, but if i have time in the morning tomorrow, i'll do a quick test piece to see how well the weave sticks to the edges of a piece of scrap metal when i apply epoxy to it. im sure it'll be TONS better than the method i was going to do. i have a buddy coming over tomorrow around noon to help me with the roof so i'll do the test piece in the early AM and it should be dry enough by noon to get a good idea of how everything works.
i need to get my car back on the road by monday (new job) so i dont have a lot of time left to try this and that. i just need to go with the flow. glass has to go back on saturday. so tomorrow will be all epoxy lay up all day, then cure overnight, then friday i'll be sanding till my arm falls off and then clear coat at night and wetsand saturday morning, saturday afternoon, glass goes back in. thats the plan anyways, we'll see how things go.
Old February 1st, 2012, 11:30 PM   #20
Brad
Yikes. It's really tough to do projects like these with such tight schedules, but props to you for trying to make it work anyways.
Old February 2nd, 2012, 12:59 PM   #21
Vimal (vee-mall)
just did a little sample piece with some complex curves, so far the CF weave is sticking to the piece very well, going to let the 3M 77 cure for an hour then slap some epoxy on it and see how well it holds after that. looks promising so far.
Old February 2nd, 2012, 07:28 PM   #22
Nice work bro
MaddMike24 is offline   Reply With Quote Quick reply to this message
Old February 2nd, 2012, 07:48 PM   #23
Vimal (vee-mall)
so brad, this method worked to a certain extent, there was still some lifting i had to deal with but not as much. also, i only did one layer of epoxy today because it just took so damn long that by the time it was tacky enough to apply another layer, i was shot and it was getting cold out. so im going to let the first layer go to full cure, then do a light sanding on it and add 2 more layers tomorrow. probably not going to get the glass on by Saturday so i'll have to borrow my dads car early next week to get to work.
anyways, pics from today...
CF glued down...
mixing resin, it cures clear
first layer of resin drying...
time to rest and add 2 more layers of resin tomorrow, maybe 3 depending how it looks. then sanding starts saturday with the glass hopefully going back in monday/tuesday.
Old February 2nd, 2012, 07:49 PM   #24
KNIGHTRIDER
sunnyincali's Avatar
Send a message via AIM to sunnyincali Send a message via Yahoo to sunnyincali
very sick my brown bro
sunnyincali is offline   Reply With Quote Quick reply to this message
Old February 2nd, 2012, 08:10 PM   #25
Brad
Hmm...I wonder why you encountered some issues still with the S77 method.
I'm sure part of it entails you having that sunroof, it really complicates the tension levels that are present throughout the roof overlay. I didn't have a sunroof to deal with so the fabric could be stretched from each side without concerns of the tension dissipating in the center. Did you apply the s77 to the sunroof area first, then worked your way to the outer edges, or vice-versa?
It's coming along nicely though, and it'll look so much better than the Di-Noc or vinyl overlays you'll see around the shows. Can't wait to see it completed!
Here's something to motivate you.
Old February 2nd, 2012, 09:04 PM   #26
I wonder if it was the super 77? Not trying to bash other peoples methods or anything, especially if they had good results. Just thought people should know if they may want to attempt this, 3M makes a much stronger, and more resilient to heat, the elements etc... Adhesive. It's actually used for putting on vinyl tops. Their super trim adhesive part # 08090. When I was doing my headliner that's what I went with after reading some troubles people had with the 76 and 77 adhesive with their cars.You look like your past the need for it though aha it looks like it's coming good though, I'm excited for results.
Rushzer0 is offline   Reply With Quote Quick reply to this message
Old February 2nd, 2012, 09:28 PM   #27
Brad
Yeah, there's s77 and s90. Vimal had both, but I suppose it's up to the individual (along with temp/humidity levels, desired curing times, etc). S77 should have been sufficient enough for this, although I'm still curious about how big of a role that sunroof area plays in complicating things.
Old February 2nd, 2012, 09:44 PM   #28
Probably a good share of it is due to that I know I personally had problems with that spot when I did my headliner, which is pretty much the same principal as this and it's practically the same area and shape as the roof only inverted.
Old February 3rd, 2012, 12:15 PM   #29
Vimal (vee-mall)
the start of epoxy layer 2...
on the next layer, instead of building up more on the flat areas, im going to mix a smaller batch and hit all the edges with a brush to build up epoxy there because im having a little bit of a hard time building up epoxy on the edges because it just runs off. the reason is does that is because unfortunately if you imagine all the edges being 90degree bends, the carbon fiber doesnt hug the 90degree bend perfectly, it sort of "apexs" the bend, meaning just before the bend, the material lifts and gradually bends around the 90degrees bends. so to lay up epoxy on these edges, i need to use a detailed brush and keep an eye on everything because when the time comes to sand everything, i need to make sure i dont sand into the fibers on the edges so the more epoxy the safer i'll be. i am likely going to apply 3-4 total layers of epoxy to give me enough of a buffer zone over the fiber to sand.
Old February 3rd, 2012, 07:57 PM   #30
Vimal (vee-mall)
dammit, i just noticed some of the epoxy is hazing its a very light haze that can only be seen at a certain angle. i tried to get a picture of it but i cant capture it with the camera. i guess im going to have to live with it because there isnt anything i can do now really. luckily i had already planned to have all my CF slightly tinted with NHBP in the future, so hopefully that will hide what light hazing is visible.
im bummed to say the least but the project must go on. the roof is still going to look great imo but not as flawless as i had hoped. i havent had a chance to move the car into the sun to see how it looks but at night the haze can be seen only in the areas where the CF pattern isnt shining through (the dark areas when looking at CF)
