SRS Indicator Light and Indiglo Gauges - Honda Accord Forum : V6 Performance Accord Forums
Old February 2nd, 2004, 10:45 AM   #1
Hello all,
My SRS Light has been on in my car ever since I installed my indiglo gauges and I've heard that if you turn on the ignition with the gauge pod removed then the SRS light will come on when you put it back in; when I was working on my car my Dad wanted me to rev up my engine for his friend, don't know why really, and I had the gauge pod out at the time, so I started up my car reved it up a bit and then turned off the ignition, finished my work and put the gauge pod back in. So I guess my question is: would that activate the indicator light, or did I do something else? Regardless, how the heck can I turn that indicator light off, because I know NOTHING is wrong with my SRS system, thanks!! BTW, does anyone have a set of indiglo gauges that glow purple? If so could you post/send me a pic, thanks
Landshark is offline   Reply With Quote Quick reply to this message
Old February 2nd, 2004, 01:19 PM   #2
Re: SRS Indicator Light and Indiglo Gauges
Originally posted by Landshark
Hello all,
only thing that comes to mind would be to reset the ECU. if you cant get it to turn off you can always but a small piece of electrical tape on the cluster behind the smoke lense over the SRS light.
Old February 2nd, 2004, 01:38 PM   #3
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
There's a thread here somewhere on resetting the srs light.
Old February 2nd, 2004, 04:57 PM   #4
Thanks for the replies....anyone know where that thread might be?
Old February 2nd, 2004, 05:26 PM   #5
try the DIY section
AF_BRYAN is offline   Reply With Quote Quick reply to this message
Old February 5th, 2004, 11:59 AM   #6
SRS Light
Here you go, I did it and it worked for me.
To reset the SRS light, here are the cliff notes -
1. bend a paper clip into a 'U' shape to create a loop
2. disconnect the yellow plug in your fuse box under the steering wheel and insert the paperclip into the plug that is now hanging there to complete the circuit
3. turn the ignition on and the SRS light will stay on for 6 seconds, then go off - disconnect the paperclip within 4 seconds after that and the light will come back on
4. reconnect the paperclip within 4 seconds and the SRS light will go off again
5. within another 4 seconds of it going off, disconnect the paperclip and the light will blink twice and it will be done
Pics:
http://www.v6performance.net/forums/...p?postid=57091
scootrz3 is offline   Reply With Quote Quick reply to this message
