sound deadening on trunk lid - Honda Accord Forum : V6 Performance Accord Forums
Old February 2nd, 2004, 03:31 PM   #1
anyone have any pictures of some type of sound deadening installed on the trunk lid?
new_guy is offline   Reply With Quote Quick reply to this message
Old February 4th, 2004, 08:18 PM   #2
Here's a pic of my trunklid.. after I took this pic I ended up putting a bunch more up on the very top of the lid and putting more down the center... you can get the general idea though.
BTW it works great.
halcyon is offline   Reply With Quote Quick reply to this message
Old February 5th, 2004, 12:15 AM   #3
does your trunk still open when you open it from the little remote?
Old February 5th, 2004, 04:39 AM   #4
Old February 5th, 2004, 08:32 AM   #5
My trunk latch releases but it does not go up by itself, i have to push it up =)
Old February 5th, 2004, 09:05 AM   #6
here's my Raammat, about 3 layers
w3accord is offline   Reply With Quote Quick reply to this message
Old February 5th, 2004, 09:29 AM   #7
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
Doesn't look like it's up against the metal a lot...... any air gap between the mounting surface and the sound deadener greatly decreases the efficiency of it.
Not hassling you, just pointing it out in case you didn't know.
Old February 5th, 2004, 11:25 AM   #8
think the way it looks might have somthing to do with the 3 layers.
ADDICTED2ICELED is offline   Reply With Quote Quick reply to this message
Old February 5th, 2004, 11:40 AM   #9
damn 3 layers.. I doubt the lid even pops up 1/2 an inch
I have one layer with some carpeting on top and the lip pops open about 2 inches and slowly rests.
Old February 5th, 2004, 02:58 PM   #10
Miami 4-Banger
papayonsens's Avatar
Send a message via AIM to papayonsens
a few layer's of Rammat, it does the job mighty well...
papayonsens is offline   Reply With Quote Quick reply to this message
Old February 5th, 2004, 03:35 PM   #11
Old Member
Du3ce's Avatar
^^^thats one clean install
Old February 5th, 2004, 04:20 PM   #12
Ya in reality my lid with just 1 layer of Extreme Dynamat doesnt pop up at all when i release the lid.. all it does is trip the latch so I can lift it up =)
Old February 5th, 2004, 06:27 PM   #13
SILVIA
EuStOn's Avatar
Send a message via AIM to EuStOn Send a message via MSN to EuStOn Send a message via Yahoo to EuStOn
how much is Rammat?? they cheap, compare with second skin?
EuStOn is offline   Reply With Quote Quick reply to this message
Old February 6th, 2004, 04:14 AM   #14
Probably not as cheap as second skin, but you'll definitely save more than buying dynamat.
www.raamaudio.com
Old February 6th, 2004, 07:11 AM   #15
hey guys, did you all just do your trunk. or did you line the rest of your trunk too?
Old February 6th, 2004, 07:50 AM   #16
I did the entire trunk... about a single layer... the real layering started at the rear parcel shelf and now I'm going to finish the interior by doing the entire floorboard, rear side lining.. and perhaps the roof if I have some leftover.. I picked up the clearance priced second skin for like $70 shipped vs $127 shipped from rammat. Rick is a cool guy... for $70 you get 50ft and for $127 you get 60ft... so it was a no brainer which one to get... or if your loaded go for dynamat extreme $130shipped for 36ft prices quoted from eBay(raamat and dynamat)
Old February 10th, 2004, 07:25 AM   #17
no pop up at all, just is unlocked but no way to tell its actually open.
Old February 10th, 2004, 01:34 PM   #18
Just a couple of questions. If I were to do the whole trunk copartment of my 04 accord coupe with iether dynomat extreme or something else, how much wieght will that add?20,30,40 pound? 2. how effective is the sound deadening in the trunk for icreased bass and decreased road and exaust noise?
Thank-you.
S.A.M6 is offline   Reply With Quote Quick reply to this message
Old February 10th, 2004, 02:41 PM   #19
Old Member
Du3ce's Avatar
it wont be much unless you start adding layers on top of that
Old February 10th, 2004, 04:29 PM   #20
It adds a lot of weight if its dynamat extreme.. I used one bulk pack and in reality could use easily another.. I'd say each pack was around 30lbs.
