custom trunk question - Honda Accord Forum : V6 Performance Accord Forums
Old February 3rd, 2004, 09:36 AM   #1
Banned
98EXL's Avatar
Hey guys,
Quick question. I want to finish my trunk by summer time, and I want to have my floor raised a little to have the amps appear under the carpet, and on hinges so I can lift the amp rack up to get to my spare. (In a nutshell) My question is, how do I secure the 'enclosure' to the floor of the trunk? Do I use self tapping screws, or what?
98EXL is offline   Reply With Quote Quick reply to this message
Old February 3rd, 2004, 09:55 AM   #2
Old Member
Du3ce's Avatar
yeah you can do that, crutchfield sells them
Old February 3rd, 2004, 10:48 AM   #3
Banned
98EXL's Avatar
crutchfield sells what, self tapping screws
Old February 3rd, 2004, 04:09 PM   #4
It depends, When I had my little enclosures I used a bolt I found behind the plastic on each side and ran some plumbers strap to the boxes. For the big one i just used some sheetrock screws and some more plumbers strap(the copper stuff with the holes) and secured two sides. If possible use existing bolts, if not make some holes, just look underneath the car first and make sure you don't hit the tank. The box I'm in the middle of building right now I use the screw that was meant for the spare tire(since I'm using the spare tire will and I have AAA )
Old February 3rd, 2004, 06:19 PM   #5
Banned
98EXL's Avatar
but your amps are on top of your enclosure, right? I want to do a psudo-false floor. I guess I could just drill into the floor, and you are right, not to hit the tank. It's my luck I would though.
Old February 3rd, 2004, 06:39 PM   #6
now they are, the old amp rack and two separate sub boxes I had the subs anchored to the sides then the rack anchored to the boxes, and one strap in the front of the rack.
Old February 4th, 2004, 08:32 AM   #7
Banned
98EXL's Avatar
I guess this will be like the LEDs in vents, everyone does it differently. We shall see how this turns out
