Which wiring harness for GS fog lights? - Honda Accord Forum : V6 Performance Accord Forums
Old February 4th, 2004, 04:49 AM   #1
J32A2 + SC + Meth AV6
BlackV62K2's Avatar
I'm not sure which wiring I need to get for the GS fog lights so they'll work for my AV6. Can I just get the Honda's OEM wiring harness (Harness A & Harness B) according to the installing guide for Honda's OEM fog lights. If those wires work, what part number are they? I also need the part number for the Honda's OEM foglight switch.
Old February 4th, 2004, 06:37 AM   #2
HONDA_99's Avatar
Of cause you can use wire harness from OEM fog light kit, but must likely you need to modify connectors for connection between wire harness and GS fog lights.
BTW, I have extra wire harness of OEM fog light kit with a switch.
One of my fog lights was busted, so I bought a kit. It was cheaper then to buy fog light and then to buy H3 bulbs, my fog lights where +4 years old so old H3 bulb and new one would look very different.
Old February 4th, 2004, 12:25 PM   #3
BlackV62K2's Avatar
Do you have the 2 part numbers for the wiring harness by any chance? I want to see how much I can get it for first @ my local dealership.
Btw, how much are you willing to sell your wire harness and switch?
Old February 4th, 2004, 12:48 PM   #4
HONDA_99's Avatar
there are only tags for A, B & C, and no part numbers. probably because its a kit.
if you want my harness, i'd let them go for $25+shipping.
Old February 4th, 2004, 12:54 PM   #5
BlackV62K2's Avatar
Ohh, so it's a wiring kit that consists of those 3 harness? Then there should be a part number for that. I'll check with my local dealership first and I'll get back to about your harness. Thanks
Does that include the switch too?
Old February 4th, 2004, 12:58 PM   #6
HONDA_99's Avatar
there are three wire harness; one for engine compartment, one for cabin and one for battery connection. there is also a switch.
Old February 4th, 2004, 01:11 PM   #7
BlackV62K2's Avatar
Looking at the installation instruction for the OEM fog lights.....there are a bunch of other stuff I'll need: Fusible link, Relay B 4-pin, Relay A 4-pin and Relay bracket. Does that come with the kit also?
Old February 4th, 2004, 02:23 PM   #8
HONDA_99's Avatar
kit includes whatever shown in instruction, and that is pretty much what i have exept fog lights.
i might pulled out zip ties out of box, but if i find them i can put them back in box.
