Panels (Window Controls) - Honda Accord Forum : V6 Performance Accord Forums
Old February 7th, 2004, 06:55 PM   #1
Hello all,
I'm trying to remove the trim around my window controls on the driver and passenger sides and I can't get them out! I'm painting my bezel, shifter and those panels if I can get them out. Anyone know how to do this? Thanks (didn't have any problems with the bezel and shifter)!
Landshark is offline   Reply With Quote Quick reply to this message
Old February 7th, 2004, 07:05 PM   #2
V Go SoCal Drivers V
bustedryde's Avatar
You need to remove the entire door panel. First unscrew the door handle and remove the corner cover towards the front. Then, it's all held by clips, you just pull off and up and over the locks. The door panels are screwed in from the underside.
Old February 7th, 2004, 07:06 PM   #3
Old Member
Du3ce's Avatar
http://www.morningz.com/mz/integra/a..._doorpanel.asp
Old February 7th, 2004, 07:17 PM   #4
Thanks for the help guys I'll try it out in the morning...
Old February 10th, 2004, 12:47 PM   #5
Hey, I checked out that link and I think I've confused you guys, I want to remove my control pod in my doors cause I wanna paint them, not the entire door panel. Also the pics in that link depict a sedan and I have a 2001 coupe and its looks like the control pod is partially underneath the door slit; does anyone know what I mean? I don't know how else to explain it. So, I hope this clarifies things. Someone let me know how to get those control pods off, cause I can't find a way....
Old February 10th, 2004, 02:05 PM   #6
bustedryde's Avatar
REMOVE your door panel, as in my first post, because the "pods" are screwed in from under/inside the door panel.
Old February 10th, 2004, 02:36 PM   #7
K, I'll give it another shot. Thank you very much!
