aftermarket wheel specs - Honda Accord Forum : V6 Performance Accord Forums
Old February 15th, 2004, 10:17 PM   #1
hey fellas i'm in the market for some wheels but there are some questions bout settings and set ups tha ti got...i am gonna be sittin on eibach sportlines which drops me 2" front and back....will 18" with 40 series work and not rub or anything and also what would the offset i should have for a 2001 av6 sedan??? thanks for all the help guys
Speedstyles408 is offline   Reply With Quote Quick reply to this message
Old February 15th, 2004, 10:32 PM   #2
HONDA_99's Avatar
+45mm offset will work just fine for your set up
for tires you can go with:
215/45-18 bigger then stock 0.5%
225/40-18 bigger then stock -1.6%
235/40-18 bigger then stock -0.4%
but you need to remember:
215mm tire will fit on 7" wide rim
225mm tire will fit on 7.5" wide rim
235mm tire will fit on 8" wide rim
Old February 15th, 2004, 10:37 PM   #3
7.5" wide will that stick out?
Old February 15th, 2004, 10:47 PM   #4
HONDA_99's Avatar
wiil not, with +45mm or higher offset
Old February 15th, 2004, 10:51 PM   #5
so get a +45mm offset and not a - offset? what would be the difference?
Old February 15th, 2004, 11:03 PM   #6
HONDA_99's Avatar
i think tirerack can explain better then i do what offset is. here is link -> http://www.tirerack.com/wheels/tech/offset.htm
Old February 15th, 2004, 11:08 PM   #7
hey honda_99 thanks alot you've been a good help...wish me luck
Old February 15th, 2004, 11:12 PM   #8
HONDA_99's Avatar
good luck
