what impedance amp to use? - Honda Accord Forum : V6 Performance Accord Forums
Old February 19th, 2004, 07:22 PM   #1
bryan <3's bomex
mastadulog's Avatar
i was looking at alpine type r's on ebay and in it says the type r uses dual 4 ohm voice coils. does this mean i have to use a 4ohm amp or is it unrelated?
-97 Accord V6-
aim: bpdulog
photos:
myspace:
hincity:
Old February 19th, 2004, 07:28 PM   #2
Old Member
Du3ce's Avatar
no you can wire it down to 2ohms also for more power, all amps will be able to do 4ohms
Old March 1st, 2004, 12:16 PM   #3
bryan <3's bomex
mastadulog's Avatar
alright, im getting kinda confused now. im getting a Audiobahn AW120T 12" sub and it runs at 4ohms and runs at 500 rms. originally i was going to use a power acoustik OV2-820 which runs at 460 rms mono, but i think that would be @ 2ohms. can i still go with that setup?
Old March 1st, 2004, 12:37 PM   #4
almost every car amp is rated at 4 ohms. the better ones will be able to handle 2,1, or less...
ADDICTED2ICELED is offline   Reply With Quote Quick reply to this message
Old March 1st, 2004, 12:49 PM   #5
yeah most home stereos SPEAKERS are 8 ohm, and car speakers are 4 ohm. A amplifier for your car will be 4 ohn if you hook it up normally, if you bridge it it will still be @ 4 ohm IF you run it to a single 4 ohm speaker, if you run it in parallel (pos/neg to 1 speaker, then jump pos/neg to the 2nd speaker) to 2 4 ohm speakers it will create a 2 ohm load for the amp, but your speakers are still 4ohm speakers.
got it?
Old March 1st, 2004, 03:06 PM   #6
bryan <3's bomex
mastadulog's Avatar
cool beans man, thanks alot!
