trunk tighten - Honda Accord Forum : V6 Performance Accord Forums
Old February 21st, 2004, 07:11 AM   #1
sittin low
AcCoRd16's Avatar
trunk tighten
Hey did you guys know that we can tighten our trunk. Well my Subs were getting the trunk loose, I can tell becuase the Taillights wasn't line up with each other. All you have to do is loosen the two bolt to the hook, then move it down a bit, then tighten up the two bolts again. I think i'm getting less rattling in the trunk.
AcCoRd16 is offline   Reply With Quote Quick reply to this message
Old February 21st, 2004, 07:13 AM   #2
sittin low
AcCoRd16's Avatar
And when i use the remote to unlock the trunk, it pop open higher before mine only pop open about an inch.
Old February 21st, 2004, 09:31 AM   #3
Old Member
Du3ce's Avatar
what do u mean? you loosen the bolt to the trunk spring or what?
Old February 21st, 2004, 11:57 AM   #4
V6P Lover
v62kaccord's Avatar
Send a message via AIM to v62kaccord
yeah that's wut i did to reduce the rattle on my trunk, and yeah when u open it wif the remote it opens more..
v62kaccord is offline   Reply With Quote Quick reply to this message
Old February 21st, 2004, 02:47 PM   #5
sittin low
AcCoRd16's Avatar
no it's not on ur trunk lid. it's the thing that the lid get lock into.
Old February 21st, 2004, 05:24 PM   #6
I did that a while ago as well. My trunk tail lights are a little lower than corners, but it really helped with the rattling.
For those that don't understand, theere's two bolts holdling the trunka latch on the body(not the trunk lid) the little U shaped thing. Loosen those, slide it down just a little tiny bit, then tighten them. It helped a lot of the major rattling for me(so did putting two bolts through the bottom of my license plate.)
