help!! blew inline fuse - Honda Accord Forum : V6 Performance Accord Forums
Old February 21st, 2004, 03:23 PM   #1
The inline fuse of my amp power wire blew. How do I go about replacing it? Do I need to replace the entire cable?
2000 Accord V6 EX
Current mods:
ICE: Eclipse 3434 HU, PPI PCX-480 Amp, Apline Type-R Component Front Speakers, MB Quart DTC-169 Rear Speakers, Infinity Basslink Sub
Exterior: 18 Axis TC Evo, Catz 4100K HID, Tenzo 200x Fog Lights, Tint, DIY Black Housing, 01-02 Front and Rear Bumper, Hi Performance Stickers
Interior: DIY Gunmetal dash, Reverse Indiglo Gauges
Suspension: Tein SS Coilovers, CL-S front strut bar, CL-S rear sway bar
Engine: AEM SR, Intake Heat Shield, Magnaflow Catback Exhaust, TL Battery Cover
Near Future mods:
Headers
Pullies
Looking for a job?
http://www.v6performance.net/forums/showthread.php?s=&threadid=17052
Old February 21st, 2004, 03:33 PM   #2
azn010's Avatar
Send a message via ICQ to azn010 Send a message via AIM to azn010
dont remember if theres a number on the inline fuse..but try to find out how man amps the fuse is and then jus go and buy a replacement fuse
azn010 is offline   Reply With Quote Quick reply to this message
Old February 21st, 2004, 04:13 PM   #3
Old Member
Du3ce's Avatar
no you just need to replace the fuse, your power wire is fine, just disconnect ur power wire to ur amp to be on the safe side
Old February 21st, 2004, 04:26 PM   #4
i believe i have this fuse holder
i can't figure out how to open it up.
2000 Accord V6 EX
Current mods:
Near Future mods:
Headers
Pullies
Looking for a job?
Old February 21st, 2004, 04:32 PM   #5
also, what fuse do I need? I am running 8 gauge wire with a basslink which i think is 200W RMS
Old February 21st, 2004, 04:34 PM   #6
each endcap will just unscrew, get an adjustable wrench and firmly hold the center barrel, and unscrew the side away from the battery(if you open the other side you have the risk of having a live unfused wire flapping around). Pull the fuse out with some needle nose if it doesn't come out from that side, there should be a fuse rating on the fuse itself, otherwise ass up teh fuses on yoru amps and subtract 5% then buy a new fuse.
If you're unsure of it, take it to a stereo shop and ask for help. They wouldn't charge more than $10 to replacve the fuse.
Old February 21st, 2004, 04:34 PM   #7
both ends unscrew, the plastic end caps, just use your hands, try not to squeeze too hard its plastic it can crack or break, do not use a pliers, it will definatly break if yoru not careful!
trinity69 is offline   Reply With Quote Quick reply to this message
Old February 21st, 2004, 04:35 PM   #8
or just do what illusion said, yeah! must have posted out answers at the same time , his answer is better though!
Old February 21st, 2004, 04:49 PM   #9
thanks for your help guys
so my basslink has a 20A fuse in it. since they don't sell 19A fuses, would 20A fuse be ok?
Old February 21st, 2004, 04:54 PM   #10
this is a little OT from my original question, but I am planning on gettin a PPI PCX-480 with the following specs
80 watts x 4 @4ohms 160 watts x 4 @2ohms 320 watts x 2 @4ohms Bridged
Would I be able to power my basslink and this amp with the 8 gauge wire I have now and simply increase the fuse? I plan to run the ppi to power my 4 speakers at 80 watts x 4 @4ohms
Old February 21st, 2004, 04:56 PM   #11
yeah 20A is good. On high power systems I usually go 5%-10% under just to be safe. My amps add up to 190A I use a 180A circuit breaker just to be safe, but there's nothing wrong with using the same rating, just don't go over.
8ga would be pushing it. I'd personally upgrade it to 4 gauge, but I'm anal about being safe.
here's a good chart to look at for current versus wire gauge and wire length. The longer the wire the more voltage drop and resistance to the wire, so more current and/or longer run means bigger wire. http://www.a1bigaudio.com/wiresize.htm
Old February 21st, 2004, 05:08 PM   #12
thanks, hopefully i can get by on the 8 gauge wire.
one more question do I need a distribution block, or can i simply split the power cable from the basslink.
Old February 21st, 2004, 05:20 PM   #13
Just depends if you want it to be pretty, you can splice the wire, solder them together and black tape them if you'de like. A distro block just helps keep things pretty. I use the bolts on cap and my distrobution point.
here's a pic from a while back to give you an idea
Old February 21st, 2004, 05:44 PM   #14
Old Member
Du3ce's Avatar
here's my digital fused d. block too lazy to hook it up
Old February 28th, 2004, 11:08 PM   #15
HOOK 'EM
blackdragon's Avatar
Send a message via AIM to blackdragon
^ wanna sell it?
blackdragon is offline   Reply With Quote Quick reply to this message
