how do you attach a front lip? - Honda Accord Forum : V6 Performance Accord Forums
Old February 27th, 2004, 08:58 AM   #1
EX-Featured Ride Coord.
DaBenz7898's Avatar
Send a message via AIM to DaBenz7898 Send a message via MSN to DaBenz7898
how do you attach a front lip securely to the front bumper?
DaBenz7898
Pics, mods, and latest updates:
** Click
** Click
DaBenz7898 is offline   Reply With Quote Quick reply to this message
Old February 27th, 2004, 12:45 PM   #2
i think it dependson the lip but as a rule of thumb its double sided tape and screws on each corner in the wheel wells and 2 or thres screws onthe underside of the lip, towards the middle. The OEM lip goes onw/out doublesided tape and it attached in the wheel wells and on the underside of the lip into the factory clip spots. Hope this helps.
Old February 27th, 2004, 05:24 PM   #3
Vimal (vee-mall)
KnightRyder's Avatar
my oem lip had a bunch of bolts underneath (2 of the were reversed, this means you would have to take the entire bumper off to get to the other two bolts. it had double sided tape along the middle portion where the lower grill is and it has two screws on each side of the lip where it attached to the bumper inside the wheel well.
Old February 29th, 2004, 11:25 PM   #4
if you put double side tape on the bumper, won't that damage the paint if you wanted to take it off?
Old March 1st, 2004, 07:04 AM   #5
unless its REALLY sticky tape it shouldn't. i had my lip taped on the bumper, i just used a hair dryer to warm up the tape a bit then it peeled right off, then just clean it up and u're good to go!
98av6 is offline   Reply With Quote Quick reply to this message
Old March 1st, 2004, 09:50 AM   #6
Send a message via AIM to five0netvv0
the double stick tape shouldn't be like crazy glue. just enough to hold your bumper in place. I don't have any screws on teh underside of my mugen lip, only the ones at the corners in the wheel well. I use double stick tape for the parts that is in the middle portion since it's not perfect and it does the job. I'm not sure about it being on a long time and how that would effect the glue bond, but i've taken it off and it was not a problem. used a little prep pad that they use in the hospital to take the sticky off.
five0netvv0 is offline   Reply With Quote Quick reply to this message
Old March 1st, 2004, 09:58 AM   #7
i didnt even used the double sided tape with mine, it held on fine. I just noticed this weekend when i took my lip off (i hit a snow mound and it cracked ) the tape was still there with the backing still on it LOL
