Can the alterator handle 100A?? - Honda Accord Forum : V6 Performance Accord Forums
Old March 6th, 2004, 07:13 PM   #1
I'm gettin an amp w/ my basslink so the fuses add up to 100amps. Will the alternator be ok?
2000 Accord V6 EX
Current mods:
ICE: Eclipse 3434 HU, PPI PCX-480 Amp, Apline Type-R Component Front Speakers, MB Quart DTC-169 Rear Speakers, Infinity Basslink Sub
Exterior: 18 Axis TC Evo, Catz 4100K HID, Tenzo 200x Fog Lights, Tint, DIY Black Housing, 01-02 Front and Rear Bumper, Hi Performance Stickers
Interior: DIY Gunmetal dash, Reverse Indiglo Gauges
Suspension: Tein SS Coilovers, CL-S front strut bar, CL-S rear sway bar
Engine: AEM SR, Intake Heat Shield, Magnaflow Catback Exhaust, TL Battery Cover
Near Future mods:
Headers
Pullies
Looking for a job?
http://www.v6performance.net/forums/showthread.php?s=&threadid=17052
Old March 6th, 2004, 10:11 PM   #2
HONDA_99's Avatar
6gen AV6 alternator (POS delphi) only put out 80A from about 1200RPM
Old March 6th, 2004, 10:23 PM   #3
so that means i can't the amp? seems like alot of ppl run much higher wattage than me.
Old March 6th, 2004, 10:34 PM   #4
HONDA_99's Avatar
Sorry, but I know absolutely nothing about Audio stuff and how it effects electrical system. but i know for sure if you hook up constant 100A load to 80A alternator it will burn diode bridge pretty quickly.
Old March 7th, 2004, 09:39 AM   #5
import tuner and rn
eolife22's Avatar
yeah dont do it , just upgrade the alternator to alterstart alternator ,
eolife22 is offline   Reply With Quote Quick reply to this message
Old March 7th, 2004, 11:15 AM   #6
lorenzo_n16's Avatar
You will blow your stock alternator. I did the exact same thing and it lasted about 5 months before dieing. Plan to buy an alterstart.
lorenzo_n16 is offline   Reply With Quote Quick reply to this message
Old March 7th, 2004, 02:00 PM   #7
you will be fine...
you will almost never see 100 amps out of your well amps....
I ran "125" amps on an 90 amp integra alternator without a problem
those fuses are worst case. you will probably not even get past 40 amps total draw at any one time...
now you should upgrade your alternator anyways, since everyone knows that delphi is ****.....and the alternators are prone to failure under stock condtitions as well....
Old March 7th, 2004, 02:09 PM   #8
well i'll run this alt until it craps out. no reason to upgrade till then
Old March 7th, 2004, 02:14 PM   #9
thats really the best thing to do...
that way YOU can decide and learn your self if it will work,....
and here is a hint for you...if you draw higher than the biggest fuse in the car which is (......the 100 amp main fuse), you will blow it ...so 100 amps isnt too high....you might be dipping into your battery alot, and mabyee need a cap....but you should be fine...
