replacing burnt bulbs - Honda Accord Forum : V6 Performance Accord Forums
Old March 9th, 2004, 02:52 PM   #1
is it possible to just take out the bulb on the driver side without going through and removing all of the headlight itself?
slowguy is offline   Reply With Quote Quick reply to this message
Old March 9th, 2004, 02:55 PM   #2
Old Member
Du3ce's Avatar
what do u mean? the turn signal bulb?
Old March 9th, 2004, 03:03 PM   #3
whoops haha the main bulb for driving, not the turn signal or the high beams
Old March 9th, 2004, 03:08 PM   #4
Send a message via AIM to SlvrBulletV6
Re: replacing burnt bulbs
I hope I am reading this correctly. But yes it is possible. I believe you can find instructions in your honda manual. But if you lost it, just unplug the bulb out of the socket then you turn the bulb a qtr turn and Voila!
SlvrBulletV6 is offline   Reply With Quote Quick reply to this message
Old March 9th, 2004, 03:17 PM   #5
Old Member
Du3ce's Avatar
turn it clockwise
Old March 9th, 2004, 09:15 PM   #6
ehh i'll be more specific, sorry. On the driver side theres the radiator reserve tank, do you guys remove this in order to replace the bulb or just remove the entire headlight and then replace it?
Old March 9th, 2004, 09:23 PM   #7
Senior Moderhater
abram2001's Avatar
you can remove the reservoir by pulling it up, and moving it out of the way, simple as pie
Old March 9th, 2004, 09:30 PM   #8
J30A1 => J30A5 => K24Z3
TH23's Avatar
The reserve tank is only blocking the driver's side high-beam. You should be able to reach the driver's side low-beam without removing anything. The intake resonator snorkel will be in the way but you can reach around and underneath that to get to the bulb.
Old March 10th, 2004, 12:11 AM   #9
yeah, the tank is blocking the high beam only.. there should be like a black cover thing you have to remove.. it has two blacks plastic things where you just pull it straight out and then you pull the black cover upwards and then you should see the low beam bulb
Vtech1213 is offline   Reply With Quote Quick reply to this message
