taking apart gauge cluster on 2k2 - Honda Accord Forum : V6 Performance Accord Forums
Old March 12th, 2004, 08:52 PM   #1
"Keep It Sleazy"
fluidjay's Avatar
I read in the forums that the plastic clear cover on the gauges is glued to the black bezel.I need to open this up to put my bezel face on. Any ideas or info?I really don't want to cut it open. This is supposedly only for the 2002 v6's.
fluidjay is offline   Reply With Quote Quick reply to this message
Old March 12th, 2004, 08:57 PM   #2
Old Member
Du3ce's Avatar
no its not glued on, its held in by plastic clips on the back, just pop it off and you should get it out
Old March 13th, 2004, 10:20 PM   #3
HOOK 'EM
blackdragon's Avatar
Send a message via AIM to blackdragon
I have an 02 AV6 as well. And on the contrary, it is both clipped and glued. Just get a knife and slowly find a spot where its not that heavy and slowly pry apart the plastic part as you unclip it. there are also two small gold hex screws/bolts on the bottom that you will have to remove as well.
blackdragon is offline   Reply With Quote Quick reply to this message
