question about 9005 conversion - Honda Accord Forum : V6 Performance Accord Forums
Old March 20th, 2004, 10:17 AM   #1
i'm using a 65W koba bulb on my low beams. has anyone else done this? will it burn my wiring harness?
new_guy is offline   Reply With Quote Quick reply to this message
Old March 20th, 2004, 05:28 PM   #2
might burn ur sockets
sh0rti is offline   Reply With Quote Quick reply to this message
Old March 20th, 2004, 06:56 PM   #3
Old Member
Du3ce's Avatar
i use to have koba bulbs but i didnt do the conversion, im pretty sure it will be ok
Old April 13th, 2004, 06:19 PM   #4
DTB
The sockets will be fine. The stock is 55w and 65w will not be too much on the setup. You will gain about 400 lumens of light more. The 9005 will burn out faster than the 9006, but it should last for atleast a year if not longer.
If you start to go higher than 65w you may want to get a wire harnes that will allow the power to come from the battery instead of the switch. Trust me, you don't wantto have your switch go out. This can be expensive to diagnosis and replace.
DTB
DTB is offline   Reply With Quote Quick reply to this message
